How to Calculate the Total Number of Particles in Different Energy States?
In summary, this conversation is about a system of N particles with three energy levels: 0, E, and 4E. The question is how many particles are expected to be in the second state at temperature T. The attempted solution initially fills the first state with 3 particles and then calculates the total number of ways to place the first three particles in the first state. However, the correct solution would involve considering temperature and the probability of finding a particle in a particular state. The correct approach would be to use equations and concepts from Statistical Mechanics by Roger Bowley and Mariana Sanchez, as referenced in the conversation.
NewtonApple
45
A system of N particles has three possible energy levels namely; 0, E and 4E. How many particles does one expect in the second state at temperature T?
It's a sample problem for our finals. Our Text book is Statistical Mechanics by Roger Bowley and Mariana Sanchez.
Three Energy levels
[itex]E_{1}=0[/itex], [itex]E_{2}=E[/itex], [itex]E_{3}=4E[/itex]
Let us first fill the [itex]E_{1}[/itex] state with 3 particle.
N distinguishable ways of selecting the first particle
N-1 different ways to select second particle
N-2 different ways to select third particle
So the total number of ways to place first three particles in state [itex]E_{1}[/itex] is
[itex]N(N-1)(N-2)=\frac{N!}{(N-3)!}[/itex]​
Generally for [itex]n_{1}[/itex] particles placed in [itex]E_{1}[/itex] is,
[itex]\frac{N!}{n_{1}!(N-1)!}[/itex]
for [itex]E_{2}[/itex] state,
[itex]\frac{(N-n_{1})!}{n_{2}!(N-n_{1}n_{2})!}[/itex]​
for [itex]E_{3}[/itex] state,
[itex]\frac{(N-n_{1}n_{2})!}{n_{3}!(N-n_{1}n_{2}n_{3})!}[/itex]​
Total number of particles in all three state will be
[itex]P=\frac{N!}{n_{1}!n_{2}!n_{3}!}[/itex]​
Substituting values
[itex]P=\frac{N!}{0!1!4!}[/itex]​
Am I on right track?
I don't think so. You haven't even invoked temperature in any way.
If you had only one particle, what would be the probability of finding in in state 2 when the temperature is T?
Likes 1 person
ok, I try to re attempt it after going through chapter 6 of the book.
1. What is statistical mechanics?
Statistical mechanics is a branch of physics that studies the behavior of systems composed of a large number of particles, such as atoms or molecules. It uses statistical methods to understand and predict the macroscopic properties of these systems based on the behavior of their individual particles.
2. How does statistical mechanics differ from classical mechanics?
While classical mechanics focuses on the behavior of individual particles in a system, statistical mechanics takes into account the collective behavior of all the particles in a system. It also incorporates probabilities and statistical methods to predict the behavior of the system, rather than relying solely on deterministic equations.
3. What are the main principles of statistical mechanics?
The main principles of statistical mechanics are the laws of thermodynamics, the concept of entropy, and the Boltzmann distribution. These principles help to explain how energy is distributed and how systems reach equilibrium.
4. How is statistical mechanics applied in real-world situations?
Statistical mechanics is applied in a wide range of fields, including thermodynamics, chemistry, materials science, and biology. It is used to understand the behavior of gases, liquids, and solids, as well as complex systems such as proteins and polymers.
5. What are some common statistical mechanics models?
Some common statistical mechanics models include the ideal gas model, the Ising model, and the lattice gas model. Each of these models simplifies the behavior of a system in order to make predictions about its macroscopic properties.
  • Quantum Physics
  • Thermodynamics
