Steam Calcs: Turbine Intake Pressure & 90% Steam Content
In summary, the problem is to determine the steam pressure at the turbine inlet in a steam power plant process with a maximum temperature of 550 degrees celsius, a condenser pressure of 0.06 bar, and an isentropic efficiency of 80%, while also ensuring a vapor quality of at least 90% in the turbine exhaust. This can be solved by using a formula for isentropic efficiency and using steam tables or a Mollier diagram to find the optimal turbine inlet pressure.
Intbive
The maximum steam pressure by the turbineintake is 550 C. Based on available cooling water the pressure in the condensor will be 0,06bar the isentropic efficency is 80 %. Decide the steam pressure at the turbine intake if the steam content is at least 90 %
We have struggled with this question for a while and would appreciate any help we can get.
I assume you mean the vapor quality of the exhaust steam is 90%
Please don't delete parts of the HW Template.
Simply saying that you've struggled to answer a problem is not showing sufficient effort to solve the problem. :frown:
You must show actual calculations to that effect and tell us exactly where you are having difficulty in proceeding to a solution. :wink:
Yes that's exactly what i mean, well we need somewhere to start since we can't find any sufficient formulas in our textbook :)
Well, it's going to take more than one formula to solve this problem. Your going to need either a Mollier diagram or a set of steam tables.
It's not clear what the turbine inlet conditions are. You mentioned the inlet temperature of 550 °C but called it pressure by mistake. Are you supposed to find the maximum turbine inlet pressure to satisfy the efficiency and the exit conditions?
Please post the actual problem statement verbatim.
Your book should have a formula for calculating isentropic efficiency. If not, you can find one on the internet.
Okay well translated as good as we can, the problem
When planning a steam power plant process, we have decided to have a maximal steam temperature of 550 degrees celsius at the turbine inlet. Based on available cooling water the pressure in the condensor will be 0,06 bar. The isentropic efficiency of the turbine is 80%. Decide the steam pressure at the turbine inlet, IF the vapor quality in the turbine exhaust have to be atleast 90 %.
OK.
This page shows you the definition of isentropic efficiency of the turbine, in case you haven't located it in your textbook:
http://www.learnthermo.com/T1-tutorial/ch08/lesson-C/pg03.php
The rest of the problem involves using steam tables or a Mollier diagram (enthalpy v. entropy) to determine the turbine inlet pressure which satisfies your conditions.
You may have to make several trial solutions to find one which is best for your purposes. Good Luck!
Okay thank you very much !
Related to Steam Calcs: Turbine Intake Pressure & 90% Steam Content
1. What is the purpose of Steam Calcs?
Steam Calcs is a tool used in thermodynamics to calculate the necessary parameters for steam turbines, specifically the intake pressure and steam content at 90% efficiency. These calculations are essential for designing and optimizing steam turbines for various industrial applications.
2. How do you determine the intake pressure for a steam turbine?
The intake pressure for a steam turbine is determined by considering various factors such as the desired output power, the type and size of the turbine, and the steam flow rate. Steam Calcs uses equations and data tables based on these factors to calculate the optimal intake pressure for a specific steam turbine.
3. What is the significance of having 90% steam content in a steam turbine?
In a steam turbine, the steam content refers to the percentage of steam present in the steam/water mixture. Having 90% steam content means that the mixture contains 90% steam and 10% water. This is important because a higher steam content leads to more efficient energy conversion and ultimately results in higher turbine output power.
4. Can Steam Calcs be used for different types of steam turbines?
Yes, Steam Calcs can be used for different types of steam turbines as long as the necessary data and parameters are provided. The tool considers the specific characteristics of the turbine and its components to accurately calculate the intake pressure and 90% steam content.
5. Are there any limitations to using Steam Calcs for steam turbines?
While Steam Calcs is a useful tool for initial calculations and estimations, it does have some limitations. It assumes ideal conditions and does not account for variations in steam properties, such as temperature and pressure, along the turbine blades. It is always recommended to use more advanced software and conduct experimental tests for more accurate results.
  • General Engineering
