How Do You Calculate the Stopping Distance of a Car?
To calculate the stopping distance of a car, the frictional force is essential, which is determined by the coefficient of friction and the normal force. The normal force for an 1800kg car is calculated as 17640N, while the frictional force, using a coefficient of 0.600, is 10584N. The initial kinetic energy of the car is 756900J, and to find the stopping distance, the work-energy principle can be applied. By dividing the initial kinetic energy by the frictional force, the stopping distance is calculated to be approximately 42.9 meters. It is crucial to use the frictional force for this calculation, as it is the force responsible for stopping the car.
bigtymer8700
The driver of an 1800kg car traveling at 29.0m/s slams on the brakes, locking the wheels on the dry pavement. The coefficient of kinetic friction between rubber and dry concrete is typically 0.600. Find the stopping distance
ive been trying to this problem forever and i know that Its just I am missing something small but i can't figure out what.
Ive solved for the KE_initial= 756900J and i know K_final= 0 I know i have to use the constant accel. equation
vf^2=vi^2 + 2as. I just don't know how to go about starting the problem all the unknowns have got me confused.
My attempt went like this. I got the F_normal by 1800kg(9.8) to get 17640N.
17640(.600) gave me 10584N which i used as the frictional force.
a=F/m so then 17640N-10584N/1800 =3.92 i used that for acceleration but i got the wrong answer i don't know where I am messing up
Energy isn't important in this case. Only speed, mass, force, distance and acceleration. You should have a formula relating them.
You have initial and final speed and mass already. You can find the frictional force. It's the coefficient of friction times the normal force. You know what the normal force is, right? It's the weight of the car.
Now, the frictional force is what's stopping the car, right? So if you know it and know the mass of the car, you can find the deceleration, and you should have a formula to get distance from all of that.
dont you need the acceleration to get the normal Force?
Nope. The mass of the car is 1800kg. To find the force you have to multiply by acceleration. Think of which way the normal force is pointing.
Normal force is pointing up i got that from my free-body diagram so i did 1800kg(9.8) to get 17640N
You're off by a zero, but yeah, that's it.
So you have the normal force. So F = u*m*a. That's your stopping force.
yea I got that far 17640(.600)= 10584N for the stopping force. but how do i go about solving for the acceleration to get the stopping distance?
Ok I got some insight on the problem and hopefully this is the way. but i know that W= K_f - K_i. I already know the car is stopping so K_final is 0.
K_i is (.5)1800kg(29m/s)^2 which gives you 756900J. Since you know Work is also W=F * s you got the Work from the KE and F=17640N. you divide 756900J/17640N to get 42.9 is that correct?
Yes, that works, but I don't understand why you insisted on using energy here. It works here because it's a simple system. If you get something more complicated, energy probably won't be "conserved", so I'd be careful and stick to forces instead.
Shouldn't you be dividing by 10584 N here? That is what the frictional force was found to be. 17640 N is the normal force.
so to get that distance you have to divide 756900/10584?
Yes. Do you understand why? The frictional force is what is causing the car to stop, not the normal force.
