Strange Trig Function solutions
WolfOfTheSteps
This is part of a problem for a nonlinear diff class... But it's the basic stuff that's tripping me up.
Find all the max/min and concavity for
v(x) = -cos(x)-Lx+1,\ \ \ 0<L<1
Here's what I do:
v'(x) = sin(x)-L
v''(x)=cos(x)
Set the first derivative to 0:
sin(x)-L=0 \Rightarrow x = arcsin(L)
Here's where I'm confused. I say
x = arcsin(L) + 2\pi n, \ \ \ \mbox{where }n \mbox{ is any integer}
But Maple says:
x = arcsin(L)+2\pi n, \ \ \ \mbox{where }n \mbox{ is any integer, OR:}
x = arcsin(L) - 2arcsin(L)+2\pi n+\pi \ \ \ \mbox{where }n \mbox{ is any integer}
Where does the -2arcsin(L) and the +pi come from?
I really want to understand this once and for all... I never took a trig class, and while I get by fine 99% of the time, I hit a brick wall when I come across this kind of stuff.
Thanks!
I think I almost understand it... The second set of values of x are the ones where the arcsin is in the II quadrant. Correct?
And obviously it makes more sense to write:
x = \pi - arcsin(L) + 2\pi n
for the 2nd set of x values.
Yeah, I think I get it now. I was just looking at the graph of arcsine, and it doesn't seem to make sense from that.
Is there a way to see that those are the solutions by looking at the arcsine graph?
Thanks.
I hope you understand the first solution.
The second part of the solution is better understood if you manipulate the terms a bit , it can be written as x = (2n+1)\pi-arcsin(L).
Noting that sin(n\pi-x)=sin(x) for all odd n, you can now see how this is also part of the solution.
If you still don't follow, perhaps substitution of values for L into the solutions can give a clearer picture.
For the graphical picture, you should use the sin(x) graph. Fix some L value, find arcsin(L), and see what other values of x, do you get sin(x)=L, that's all.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
