String Tension not sure on the answer i have.
  • Thread starter Thread starter pat666
    String Tension
The discussion revolves around calculating various properties of a stretched wire, including wave velocity, tension per unit area, and Young's modulus. The calculated velocity of the transverse wave is 150 m/s, while the tension per unit area is derived as 1.8 x 10^8 N/m². Young's modulus is determined to be 1.8 x 10^9. There is some uncertainty among participants regarding the calculations, particularly for the tension per unit area, suggesting a need for verification. Overall, the calculations appear consistent, but participants are seeking confirmation of their results.
pat666
A wire of material having density of 8.0 g.cm-3 is stretched so that its length is increased by 0.10%. The fundamental frequency of transverse vibrations of a part of the wire 50.0 cm long is then 150 Hz. Calculate:
(a) the velocity with which a transverse wave is transmitted along the stretched wire,
(b) the tension per unit area of cross-section of the wire,
(c) Young’s modulus for the material of the wire.
I have solved this--- a) is simple the wave length is 0.5*2 therefore the velocity is 150m/s
b) it says per unit area of cross section. however i have rho times Area = mu which ends up giving me a Tension by unit area of 1.8*10^8n*m^2 not per if you get what i mean
c) is simple enough F/A=deltaL/L * Y the Area cancels (suggesting my answer for b is right) and so do the L's leaving a youngs modulus of 1.8*10^9
can someone do this and see if they agree with me please...
Hey Pat,
I agree with your answers for all of them. I am not sure if you done b the same as me, but i used v = SQRT.(T/\mu). I done these before i even looked at your thread so either we bothed stuffed it up, they seem pretty out ..
