Strong Steel wire but an elastic spring? Why?
Steel wire exhibits strong tensile strength, allowing it to function as an elastic spring when coiled. The coiling process enables the wire to withstand twisting motions and opposing torques, similar to how a straight rod would resist such forces. Stress and strain can be analyzed in both the straight and coiled forms under torque applications. When loaded axially, the coiled spring's resistance to shear and bending can be neglected, focusing solely on the axial load. Understanding these principles can clarify the mechanical behavior of steel wire in spring applications.
tlfx1996
The steel wire can withstand strong tensile stress, but when the steel wire is being coiled into a spring it can be an elastic spring. Why is this? Can this be proven mathematically?
How much resistance will that strong steel wire provide against a twisting motion, opposing torques applied to opposite ends of the wire, which is most of the relative deformation in the case of a spring?
I'm sorry, can you explain your answer straight away. Ii'm not sure of the answer. thx
A straight rod will have some resistance to being twisted or having a torque applied to it. There will be a stress and strain asscociated with the amount of twist.
Now coil up the rod into the shape of a coiled spring. If a force is put on the spring, the rod, or rather a cross section through a part of the coiled rod, even though coiled up, can be analyzed for the stress and strain in the same manner as the straight rod experiences a torque.
For a coiled spring loaded axially,
http://www.codecogs.com/library/engineering/materials/springs.php
http://nptel.iitm.ac.in/courses/Web...ials/lects & picts/image/lect20/lecture20.htm
When they say shear and bending can be neglected, they mean a pure axial load, so no sideways force or a moment is to be applied to the spring.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
