Structure of the wave function space F
norbert
hello all
I have some concerns about Structure of the wave function space F I am referring to chapter II of QUANTUM MECHANICS OF Cohen-Tannoudji
The item A-1.a of this chapter say:
It can easily be shown that F satisfies all the criteria of a vector space. As an example, we demostrate that if \psi1(r) and
\psi2(r) \in F. then*
\psi(r) = \lambda1\psi1(r) + \lambda2\psi2(r) \in F
where \lambda1 and \lambda2 are two arbitrary complex numbers
In order to show that \psi(r) is square integrable
expand \left| \psi(r)|2 :
\psi(r)
|\psi(r)|2 = |\lambda1|2|\psi1(r)|2 + |\lambda2|2|\psi2(r)|2 + \lambda1*\lambda2\psi1^{}*(r)\psi2(r)+\lambda1\lambda2\psi1(r)\psi2*(r)
|\psi(r)|2 is therefore smaller than a function whose
integral converges, since \psi1
and \psi2 are aquare-integrable
Yes, and more?
On my last comment referred to the space functions F we have the |\psi(r)|2 expanded expression given by (A-3)
The last two terms of (A-3) have the same modulus, which has as an upper limit:
|\lambda1||\lambda2|[|\psi1(r)|2 + \psi2(r)|2]
Its OK, tha last two terms have the same modulus.
The question is:
Why the last two terms of (A-3) have the above expression??
What does mean "upper limit"??
What is the relation of this question with "triangular inequality" referred to complex-variable?
see Churchil -----"Analysis of complex-variable"-----
The Author´s comment is not clear for me
Can someone explain me this a little better?
thank you
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
