How Do You Calculate the Probability of Multiple Seeds Sprouting?
In summary, the probability that a seed will sprout is 3/4. If 7 seeds are planted, find, to the nearest ten-thousandth, the probability that at least 5 will sprout.
orchdork89
"The probability that a seed will sprout is 3/4. If 7 seeds are planted, find, to the nearest ten-thousandth, the probability that at least 5 will sprout."
The answer is .7564, but I don't know how to get there. I tried (3/4^5) + (3/4^6) + (3/4^7), but that doesn't work. Neither does (3/4*5) + (3/4*6) +(3/4*7)... am I overthinking the question, or is there a formula involved that I don't know?
Thanks!
This is a binomial distribution problem.
You have n seeds. What is the probability that exactly k seeds will sprout?
Take into account that the specification of which will sprout and which don't is not important.
Now, remember that the events of whether a seed sprouts or not is independent of whether the other seeds sprouts.
Also, the probability that a single sprout EITHER sprouts OR not sprouts is obviously:
[tex]1=\frac{1}{4}+\frac{3}{4}[/tex]
where 1/4 is the probability of non-sprouting, 3/4 the probability of sprouting.
Suppose we only have TWO seeds
Consider the following identity:
[tex]1=(\frac{1}{4}+\frac{3}{4})^{2}=\frac{1}{4}*\frac{1}{4}+2*\frac{1}{4}*\frac{3}{4}+\frac{3}{4}*\frac{3}{4}[/tex]
Now, the first term, 1/4*1/4=1/16 is clearly the probability that neither of the two seeds sprouts, the second term, 2*1/4*3/4=6/16 must be the probability that only one of the seeds sprouts, whereas the last term, 3/4*3/4=9/16 is the probability that BOTH sprout.
Considering this, how could you set up a similar scheme for the probabilities for 7 seeds?
arildno, that sounds much more complicated than necessary!
Here's how I would do it:
What is the probability that all 7 will sprout? You should know enough to argue that, assuming the sprouting of one seed is independent of the others, you just multiply the probabilities: (3/4)(3/4)(3/4)(3/4)(3/4)(3/4)(3/4)= (3/4)7.
What is the probability that exactly 6 will sprout? Well, what is the probability that the first 6 sprout but the last doesn't. Again it is the individual probabilities multiplied together: (3/4)(3/4)(3/4)(3/4)(3/4)(3/4)(1/4)= (3/4)6. But we're not done: what about the first 5 sprout, the sixth doesn't, and the seventh does sprout? Since multiplication is commutative, that will be again exactly (3/4)6 and, in fact, for any of the 7!/(6!1!)= 7 different ways that could happen (Taking "S" to mean that seed sprouts and "N" to mean it doesn't, we ould have SSSSSSN, SSSSSNS, SSSSNSS, SSSNSSS, SSNSSSS, SNSSSSS, or NSSSSSS, 7 possible orders) it will be (3/4)[/sup]6[/sup](1/4) for each and so the probability exactly 6 seeds sprout is 7(3/4)[/sup]6[/sup](1/4).
What about 5 sprounting and 2 not? Hopefully, you can see now that the probability of a particular order but any order, is (3/4)5(1/4)2. Now how many different orders can we have where 5 sprout and 2 do not? How many different order for the letters SSSSSNN are there? This is where the "binomial coefficient comes in.
Once you have found the probability that exactly 7, exactly 6, and exactly 5 seed sprout, add them.
Why is [itex]1=1^{7}[/itex] a complicated identity?
Okay, I'll admit I have an unreasonable fondness for the expression..
Well, now that you put it that way!:rolleyes: It did occur to me when I typed that that you might well consider what I did too complicated!
ummm... :bugeye: please take into account that I am 16 and stupid
Well, did you understand how we might find the probabilities of events in the case of two seeds?
For example, referring to my earlier post:
Of two seeds, what must be the probability that AT LEAST one seed sprouts?
this might help
by the binomial distribution
we have to consider the prob of either 5 or 6 or 7 sproutings
Thus
7C5 (3/4)^5 (1/4)^2 + 7C6 (3/4)^6 (1/4) + 7C7 (3/4)^7
C stands for combination (hope you understand the binomial notation)
Cheers
Sparsh
Related to How Do You Calculate the Probability of Multiple Seeds Sprouting?
1. What is probability?
Probability is the measure of the likelihood of an event occurring. It is expressed as a number between 0 and 1, where 0 indicates impossibility and 1 indicates certainty.
2. How do you calculate probability?
To calculate probability, you divide the number of favorable outcomes by the total number of possible outcomes. This is known as the probability formula: P(E) = Number of favorable outcomes / Total number of possible outcomes.
3. What is the difference between theoretical probability and experimental probability?
Theoretical probability is based on the assumption that all outcomes are equally likely, while experimental probability is based on actual trials and data. Theoretical probability is calculated using mathematical principles, while experimental probability is based on real-world observations.
4. How can I use probability in real life?
Probability can be used in many real-life situations, such as predicting the weather, gambling, and making financial decisions. It can also be used in fields like medicine, engineering, and economics to make informed decisions and predictions.
5. What are some common misconceptions about probability?
One common misconception is that if an event has not occurred in a while, it is more likely to happen in the future. This is known as the Gambler's Fallacy. Another misconception is that if two events are related, one must cause the other. However, correlation does not necessarily imply causation.
  • Precalculus Mathematics Homework Help
