Stuck on Torque Question (W/ Picture)
A uniform beam of 6.6 meters, weighing 42.67 Newtons, supports an additional weight of 19.62 Newtons at an angle of 16 degrees. The discussion revolves around calculating the tension in the supporting cable, as well as horizontal and vertical pin joint forces. Initial calculations for vertical force yield 62.29 Newtons, while tension calculations initially suggested 259.8 Newtons, later corrected to 142.8 Newtons after proper torque considerations. The resultant force from horizontal and vertical components is calculated to be approximately 155.89 Newtons, with emphasis on determining the angle it makes. The conversation highlights the importance of accurately applying torque equations and vector addition in solving the problem.
tachu101
A uniform beam of 6.6 meters with a weight of 42.67 Newtons is pinned to a wall and supports a weight of 19.62 Newtons.The beam is angled up at 16 degrees and the right end of the beam is supported by a cable attached to the other side of the wall. Find the value of; Tension of the cable, horizontal Pin Joint Force, vertical Pin Joint Force, and the resultant of the H and V force components (where the angle is measured counter clockwise from the horizontal).
I am not sure how to start this problem I only know that summing the forces in the x, y and torque direction will be used.
I tried summing the forces
\sumx = H-T=0 ---- so H=T ? (but what are the numbers)
\sumy = V - 42.67Newtons(weight of beam) - 19.62Newtons(weight at end) = 0 (am I missing any?) This would give me V= 62.29 Newtons
(If pin joint is the pivot point)
\sum\tau = H(0)+V(0)-42.67N(3.3cos16)-19.62N(6.6cos16)+T=0
I don't know if this one is right, something does not seem right with the tension part.
If this is right that would make the Tension = 259.8N ; which seems too much
And because T=H I would think that H would also equal 259.8 Newtons
The last part I have no idea what to do.
Good. Don't worry about the numbers. You'll solve for the numbers by combining all three equations.
Good.
You forgot the moment arm for the tension force. You need the torque due to the tension force, not just the force.
So it would be
H(0)+V(0)-42.67N(3.3cos16)-19.62N(6.6cos16)+T(6.6cos16) or T(6.6sin16)=0
Well, which is it? :wink: Which gives the perpendicular distance to the line of force? The tension acts horizontally.
um, if this was a test I probably would have to go with cos , but I would not be sure.
H(0)+V(0)-42.67N(3.3cos16)-19.62N(6.6cos16)+T(6.6cos16)=0
T= 40.955 Newtons
But you used cosine for the other forces, which were vertical. What's the difference?
Perhaps you should review calculating torques: http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html#tc"
I think that I get it now so (vertical cosine / horizontal sine) ----
H(0)+V(0)-42.67N(3.3cos16)-19.62N(6.6cos16)+T(6.6sin16)=0
T= 142.8 Newtons
How do I start the last part?
What's the last part? Finding the resultant?
You found T, H, and V. Now find the resultant of H and V. (Remember that these are just horizontal and vertical components of some resultant force. Use right triangle geometry to solve for the resultant and the angle it makes.)
I this like adding vectors?
I am getting 155.89 Newtons
Absolutely.
That looks about right.
thanks so much
Don't forget to figure out what angle it makes. (I think they want that specified, not just the magnitude.)
