Stuck with Optimisation question, help?
The discussion revolves around an optimization problem involving the function S=8x²ln(1/2x), where participants seek to find the value of x that maximizes S. The context includes differentiation and the application of calculus principles.
  • Participants discuss the differentiation of the function, with some questioning the correctness of the original poster's derivative. There are requests for clarification on differentiation steps and the application of rules like the product rule. Some participants express confusion over the terms involved in the differentiation process.
The discussion is active, with participants providing guidance on differentiation techniques and questioning the original poster's understanding of the derivative. There is a mix of interpretations regarding the differentiation process, and some participants are exploring the implications of the results without reaching a consensus.
There is a note that x is a ratio and cannot equal zero, which may affect the optimization process. Additionally, some participants suggest that the original problem may not have been fully presented, leading to confusion in the discussion.
CallumC
S=8x2ln(1/2x)
Find the value of x that gives a maximum.
So far I have got, by differentiating: x2+ln(1/2x). [could be wrong]
Btw the way in the question x is a ratio and so cannot equal zero.
Please help and explain how to do it thanks :)
First, brush up on taking derivatives. What you have in the OP is way wrong.
Can you show the steps you took when you differentiated the function?
I'll take you through my working:
[itex]\frac{dS}{dx}[/itex]=16x3+16xln(1/2x)
16x3+16xln(1/2x)=0. For maximum
16x(x2+ln(1/2x))=0
X2+ln(1/2x)=0
16x(x2+ln(1/2x))=0
X2+ln(1/2x)=0
I'm confused. In the OP, S = 8x^2 * ln(1/2x)
In post #4, dS/dx = 16x^3 + 16x*ln(1/2x)
I think it would be better if you post the entire problem from the beginning and don't try making shortcuts.
yeah the power rule bud, did you use it right?
I was using the product rule: [itex]\frac{d}{dX}[/itex](fg)=f[itex]^{|}[/itex]g+fg[itex]^{|}[/itex]
okay so the first part doesn't vanish they both have x terms so it seems like you lost a a term :/ the natural log term
Confused :confused: can someone write out the correct solution?
Is that the original problem?
Sorry, we don't do that here at PF.
Look, you don't have a problem with optimization. You have a more basic problem with understanding how to take a derivative.
I don't believe I have a problem with basic differentiation as I have studied it for well over a year and have been fine with it, however I am definitely not an expert. Where about do you believe the problem lies?
I think I could have the answer if someone just helps me find x from: (x+ ln(1/2x))=0
CallumC said:
(x+ ln(1/2x))=0
Is this the original question?
Original Question:
A communications cable has a copper core with a concentric sheath of insulating material. If x is the ratio of the radius of the core to the thickness of the insulating sheath, the speed of a signal along the cable is given by:
S=8x2ln([itex]\frac{1}{2x}[/itex])
Find the value of x that gives the maximum speed.
okay. ## S_{x}## is what you need that is the partial derivative of S with respect to x, so you get something that looks like this after taking the first derivative ##S_{x} = -16x ln( {2x} ) - 4x## So what I did was product rule then chain rule, I am not exactly sure if the last part with subtraction is right I am a little rusty with natural logs so that means that ##dS = S_{x} dx## that should be what you need. But there is still the problem of max. and what you can do to find the max is second derivative test... I think I am missing one term but I am not sure...
Partial derivatives?? Why do you need them here. This is a single variable problem. Please don't confuse the OP by bringing up multivariable calculus.
Tenshou: Don't help if you can't solve the problem.
  • · Replies 25 ·
