Is the Set of Functions with a Zero Integral a Subspace of C[a,b]?
In summary, the conversation is about determining whether a given set of functions, defined as the integral of the function from a to b equaling 0, is a subspace of the vector space C[a,b]. The criteria for being a subspace is that the set must follow two axioms: (i) if two elements are in the set, then their sum must also be in the set, and (ii) if an element is in the set and multiplied by a scalar, the result must also be in the set. The question also clarifies that C[a,b] could potentially be the set of all continuous functions defined on [a,b]. Lastly, the conversation mentions using properties of the integral to solve the question.
jaredmt
121
Determine whether or not the given set is a subspace of the indicated vector space:
Functions f such that [integral from a to b]f(x)dx = 0; C[a,b]
(not sure how to do the coding for integrals)
to be a subspace it must follow these axioms:
(i) if x and y are in W, then x + y is in W.
(ii) if x is in W and k is any scalar, then kx is in W.
im having trouble understanding this. what exactly is C[a,b]?
could it be the set of all continuous functions defined on [a,b]?
is there any more to the question?
0 + 0 = 0
c0 = 0 where c is an arbitrary constant.
Use properties of the integral.
What is a subspace of a vector space?
A subspace of a vector space is a subset of the vector space that still satisfies the properties of a vector space. This means that it is closed under addition and scalar multiplication, and contains the zero vector.
How do you determine if a subset is a subspace of a vector space?
To determine if a subset is a subspace of a vector space, you must check if it satisfies the three properties of a vector space: closure under addition, closure under scalar multiplication, and containing the zero vector. If all three properties are satisfied, then the subset is a subspace.
Can a subspace of a vector space contain infinite elements?
Yes, a subspace of a vector space can contain infinite elements. This is because the properties of a vector space do not specify a limit on the number of elements that can be contained in a subset.
What is the difference between a subspace and a spanning set?
A subspace is a subset of a vector space that satisfies the properties of a vector space, while a spanning set is a set of vectors that can be used to represent all the vectors in a vector space. A subspace can be created using a spanning set, but a spanning set does not necessarily create a subspace.
How are subspaces related to linear independence?
Subspaces and linear independence are closely related. A set of vectors is linearly independent if none of the vectors can be written as a linear combination of the others. A subspace can be created using a linearly independent set of vectors, as they form a basis for the subspace.
10K
