Substitution/Elimination to find General Solution | System of ODE's
Lahooty
Use substitution/elimination to find the general solution.
dx/dt = 3x-y+2t^2
dy/dt = 4x-2y-8t^2
I'm practically clueless on how to solve this problem using substitution/elimination, I'm pretty sure the way I'm doing it is completely wrong. If anyone can show me the correct approach or can show an example it would be a tremendous help.
dx/dt = 3x - y +2t^2
dx = (3x -y +2t^2)dt
x = 3xt - yt + 2/3t^3
x(1-3t) = - yt + 2/3t^3
x = (-yt + 2/3t^3)/(1-3t)
I know this is not the correct way but I can't find anything online, so if someone does know what to do please reply.
Thanks
x is a function of t. If you integrate it, you get \int x(t)\,\mathrm{d}t, not xt. Similarly for y.
dx/dt = 3x-y+2t^2
dy/dt = 4x-2y-8t^2
We want to eliminate either x or y and its derivatives to get a second order ODE for whichever variable we're left with.
Here it seems easiest to eliminate y, since the first equation tells us that
y = 3x - \frac{\mathrm{d}x}{\mathrm{d}t} + 2t^2
Differentiating this gives
\frac{\mathrm{d}y}{\mathrm{d}t} = 3\frac{\mathrm{d}x}{\mathrm{d}t} <br /> - \frac{\mathrm{d}^2x}{\mathrm{d}t^2} + 4t
You can now substitute these expressions for y and dy/dt into the second equation.
Thanks for the response and help. Alright so here is what I did:
y = 3x- x' + 2t^2;
(3x- x' + 2t^2)' = 4x -2(3x- x' + 2t^2) + 2t^2;
3x' - x'' + 2t^2' = 4x -6x + 2x' -4t^2 + 2t^2
x'' - x' -2x = 2t^2' - 2t^2
r^2 - r - 2 = 0
r = 2, r = -1
I don't know how to proceed from this point on.
y = 3x- x' + 2t^2;
The second equation is y&#039; = 4x - 2y - 8t^2, so you should have
<br /> (3x- x&#039; + 2t^2)&#039; = 4x -2(3x- x&#039; + 2t^2) - 8t^2<br />
which yields
<br /> 3x&#039; - x&#039;&#039; + 4t = 4x - 6x + 2x&#039; - 4t^2 - 8t^2<br />
(because (2t^2)&#039; = 2(2t) = 4t) so that
<br /> x&#039;&#039; - x&#039; - 2x = 4t + 12t^2<br />
r^2 - r - 2 = 0
r = 2, r = -1
You need to find a solution of
and add to it the general solution of
<br /> x&#039;&#039; - x&#039; - 2x = 0<br />
The second part you should know. For the first part, the form of the right hand side suggests taking f(t) = at^2 + bt + c with constants a, b and c, which you should choose so that f&#039;&#039; - f&#039; - 2f = 4t + 12t^2.
That gives you x(t), and you can then find y(t) from y = 3x- x&#039; + 2t^2.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
