How Are Step Functions Used in Calculating Fourier Transforms?
Step functions are utilized in calculating Fourier transforms by defining intervals where the function takes specific values. The discussion centers on the function x1(n) represented as u(n+N) - u(n-N-1), which equals 1 for the range -N ≤ n ≤ N and 0 elsewhere. Participants analyze how to derive this result using a number line to visualize the behavior of the step functions. There is confusion regarding the endpoints and the correct interpretation of the intervals, particularly concerning the values of N and n. Clarification is sought on the algebraic steps leading to the conclusion, emphasizing the importance of correctly identifying the intervals defined by the step functions.
mickonk
Hi. Here is one example from my book.
Calculate Fourier transform of signal:
Here is solution:
We can write x(n) as:
where x1(n) is u(n+N)-u(n-N-1). We can write:
(we used that cos(n)=(1/2)*(exp(j*n)+exp(-j*n)).
Using properties of Fourier transform of discrete signal:
Fourier transform of our signal will be:
We will find Fourier transform of x1(n):
How they calculated that u(n+N)-u(n-N-1) equals 1 for -N<=n<=N and 0 for other values of N?
Try setting up a number line with -N and N + 1 on it, and then mark the intervals on that number line where u(n + N) and u(n - N - 1) are either 0 or 1.
You should be able to use that to say something about where u(n + N) - u(n - N - 1) is then 0 or 1.
Here is how I tried to solve this algebraically.
We have function u(n+N)-u(n-(N+1)). Let's say N is some positive number, for example N=1.
1. When n is less then -N, for example n=-2, we have u(n+N)-u(n-(N+1))=0-0=0.
2. When -N<n<N+1 , for example n=-0.5, we have u(n+N)-u(n-(N+1))=1-0=1.
3. When n>N+1, for example n=3, we have u(n+N)-u(n-(N+1))=1-1=0.
So our function equals 1 for n between -N and N+1 but solution from my book doesn't agree with it?
Take care to consider the endpoints of your intervals. What happened to -N?
Also, n and N are integers.
What happened to N + 1?
