Suggestions/tutorial to build clock-like lazy susan?
  • Thread starter Thread starter ebsseattle
    Build
To build a turntable using a lazy susan for photography, a simple method involves attaching a large gear to the lazy susan and using a single nail as a catch for rotation. Accuracy within low tolerances is acceptable, allowing for manual adjustments using drawn radial lines instead of precise divisions. For more structured increments, standard dividing engine methods like a worm and wheel with an index plate can be employed. An index scale can be added to the turntable's rim using either a tape measure or printed segments for easy reference. Automation is not necessary, as the goal is to achieve roughly even increments for effective object rotation.
ebsseattle
I'd like to build a simple turntable using a lazy susan and a bunch of spokes (anywhere from 245-360) so that I can rotate the lazy susan one notch at a time and take a photo of an object sitting on tip of it. The goal is to hold a camera steady on a tripod and rotate the object.
Can anyone suggest materials to use to set this up without manually having to go in and split a circle in 250 parts and hand-drive 250 nails into the wheel?
Get a large gear with the right number of teeth and glue it to the lazy susan, then put just one bendy mail into the base plate as a catch.
Is it necessary that they are accurate within a low tolerance? What if you just drew out 360 radial lines in pencil and manually moved the base? If you were looking to animate it, it's not like a deviation of a 1/2 degree in one frame will be noticeable.
Stepper motor and a bit of DIY electronics is easiest way .
Otherwise :
(a) Use standard dividing engine methods - worm and wheel with index plate .
(b) Put an index scale on rim of turntable . Two methods:
Use a length of tape measure to make a loop and adjust diameter of turntable so that loop just fits over .
or
Print out a scale with suitable divisions on your printer (probably in sections) and fit as for tape measure loop . Alternatively fit as segments on the flat .
Yeah. Worm gear would work well. It can subdivide the increments of the larger gear into a fraction of a tooth.
Unless you say so, I don't think it needs to be automated.
Thanks for the suggestion. No, it doesn't need to be automated, and DaveC426913, it doesn't have to be mechanically precise. I just wanted something that has roughly even increments.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
