What is the sum of the infinite series 1/[n(n+1)(n+2)]?
The infinite series 1/[n(n+1)(n+2)] can be summed using partial fractions, leading to a telescoping series. The partial sum is expressed as S = 1/4 - 1/[2(n+1)(n+2)], which simplifies to 1/4 as n approaches infinity. Discussions highlight the use of the psi function and its properties to derive the sum. Ultimately, the sum of the infinite series is confirmed to be 1/4.
adamg
hey, i was just wondering if anyone could help find the sum of the infinite series defined by 1/[n(n+1)(n+2)]. I can split it into partial fractions but not sure from there. Thanks
Mathematics news on Phys.org
its a/(1-r)...
where |r| < 1
where a is the initial values (1/6), and r is the common ratio...
it to late for my brain to think right now so I can tthink of what the ratio is going to be.. wil try tomorrow if nobody else has helped you.. going tp sleep now..gonight!
I'm not sure the splitting can do you any good,because each of the series you'd be geting would be infinite.If you don't know the answer,well,my Maple said it's 1/4...i don't know how it did it...
I'm going to check it in G & R,too...
Daniel.
i thought you could do it by splitting it into partial fractions, then finding an expression for the nth partial sum and let n tend to infinity
According to Maple,the partial sum is:
\sum_{k=1}^{n}\frac{1}{k(k+1)(k+2)} =-\frac{1}{2(n+2)(n+1)}+\frac{1}{4}
If you can find a way to prove what I've just written,then that's it...
Daniel.
I think partial fractions is promising too -- with care, you can probably arrange the terms into one or more telescoping series. What did you get when you applied partial fractions?
Here's the proof for the partial sum:
S=:\sum_{k=1}^{n}\frac{1}{k(k+1)(k+2)}=\frac{1}{4}-\frac{1}{2(n+1)(n+2)}(1)
Use partial fractions to rewrite the initial partial sum as:
S=\sum_{k=1}^{n}\frac{1}{k(k+1)(k+2)}=\sum_{k=1}^{n}\frac{1}{2k}-\sum_{k=1}^{n}\frac{1}{k+1}+\sum_{k=1}^{n}\frac{1}{2(k+2)} (2)
According to Maple each of the three sums is:
\sum_{k=1}^{n}\frac{1}{2k}=\frac{1}{2}\psi(n+1)+\frac{1}{2}\gamma (3)
\sum_{k=1}^{n} \frac{-1}{k+1}=-\psi(n+2)+1-\gamma (4)
\sum_{k=2}^{n} \frac{1}{2(k+2)}=\frac{1}{2}\psi(n+3)-\frac{3}{4}+\frac{1}{2}\gamma(5)
Add (3)->(5) and equate with (2):
S=\frac {1}{4}+\frac{1}{2}\psi(n+1)-\psi(n+2)+\frac{1}{2}\psi(n+3)(6)
Now,use the property of "psi":
\psi(z+1)=\psi(z)+\frac{1}{z} (7) for z\neq 0
to write:
\psi(n+2)=\psi(n+1)+\frac{1}{n+1} (8)
\psi(n+3)=\psi(n+2)+\frac{1}{n+2}=\psi(n+1)+\frac{1}{n+1}+\frac{1}{n+2} (9)
to rewrite the "3-psi" term from (6) simply as:
-\frac{1}{2(n+1)(n+2)} (10)
Then add (10) to 1/4 from (6) to get the equality you were supposed to prove... :wink:
In the initial equality set n\rightarrow +\infty to get the answer \frac{1}{4}
Daniel.
What do you think of this decomposition?
<br /> \frac{1}{k (k+1) (k+2)} = \frac{1}{2}<br /> \left(<br /> \frac{1}{k} - \frac{1}{k+1} - \frac{1}{k+1} + \frac{1}{k+2}<br /> \right)<br />
That one gives the answer,too...1/4...
Daniel.
i got this far, then not sure how to cancel terms to find the sum?
Well,it's not difficult.You may write it as
\frac{1}{2}[(\frac{1}{k}-\frac{1}{k+1})-(\frac{1}{k+1}-\frac{1}{k+2})]
and then give values to "k" to see the pattern the terms take...
Daniel.
yeah got it now, thanks for all the help!
Daniel.
Thanks, didn't have a clue. Turns out the first one is the following:
\sum_{k=1}^{n}\frac{1}{2k}=\frac{1}{2}\{\frac{\int_0^\infty e^{-t}t^{n}\ln(t)dt}{\int_0^\infty e^{-t}t^{n}dt}+\int_0^\infty \frac{1}{t}(\frac{1}{1+t}-e^{-t})dt\}
I had no idea! Does Adamg know this? Don't mind me, I mean I had problems with Leibnitz's rule the other day. I tell you what though, if I was the teacher assigning this problem, we'd be looking at these integrals. Now how in the world does the sum turn out to be this messy expression?
It comes from the logarithmic derivative of the Gamma Euler function,which is "psi"...
Daniel.
Is an easy sum:
\sum\frac{1}{n(n+1)(n+2)}=\sum\frac{1}{2n}+\frac{1}{2(n+2)}-\frac{1}{n+1}= (\frac{1}{2}+\frac{1}{4}+\frac{1}{6}+\frac{1}{8}+\frac{1}{10}...+\frac{1}{6}+\frac{1}{8}+\frac{1}{10}+...+(-\frac{1}{2}-\frac{1}{3}-\frac{1}{4}-\frac{1}{5}-\frac{1}{6}-...) = \frac{1}{2}+\frac{1}{4}+\frac{1}{3}+\frac{1}{4}+\frac{1}{5}+... +(-\frac{1}{2}-\frac{1}{3}-\frac{1}{4}-\frac{1}{5}-\frac{1}{6}-...) = \frac{1}{4}.
