Sum to Infinity of a Geometric Series
odolwa99
Q.: A geometric series has first term 1 and common ratio \frac{1}{2}sin2\theta. Find the sum of the first 10 terms when \theta = \frac{\pi}{4}, giving your answer in the form h - \frac{1}{2^k}, where h, k \in N.
Sn = \frac{a(1 - r^n)}{1 - r}, when IrI < 1
S10 = \frac{a(1 - r^n)}{1 - r}
S10 = \frac{1(1 - (1/2)sin2(\pi/ 4) to the power of 10}{1 - (1/2)sin2(\pi/4)} ... The tags did not take, for some reason, hence the 'to the power of 10'. Sorry about that.
I'm stuck here because if I solve for \frac{1}{2}sin2\theta, I get a decimal answer = 0.013706. The question wants the answer defined as whole numbers but I'm unable to work out the next step in the sequence. Can someone help and give me a tip on what to do next? Thanks.
Ans.: From textbook: 2 - (1/ 29)
How did you get that?
\sin(2\theta)=\sin(\pi/2)
has a nice answer, no?
Ok, so the sum is now...
\frac{1 - (1/2)sin(\pi/ 2)tothepowerof10}{1 - (1/2)sin(\pi/ 2)}
so...
1 - (1/2)sin(\pi/ 2)10 = 1 - (1/2)sin(\pi/ 2)
1 - 1 - (1/2)sin(\pi/ 2)10 + (1/2)sin(\pi/ 2)
- (1/2)sin(\pi/ 2)9
Ok, obviously I'm wrong but this is what my attempt looks like. Thanks for the help so far but can you help me out a little bit more...please? Thanks.
What is \sin(\pi /2)?? Isn't that a nice value?
Err...In a right angled triangle, Sin( \theta ) = Opposite/ Hypotenuse...?
Go check your trigonometric formula's...
You should really know things like \sin(0) and \sin(\pi/2) by heart.
Ok. Sorry about all this. It's literally been years since I last studied maths and I'm having to begin from scratch all over again. You'll have to be patient with this old man. I'll see what I can find out from your advice and show my work tomorrow. Good night.
It's alright. This might be helpful: http://en.wikipedia.org/wiki/Trigonometric_identities
Ok, so here is, hopefully, my final attempt...
S10 = \frac{1(1 - (1/2)sin2(\pi/ 4)tothepowerof10)}{1 - (1/2)sin2(\pi/ 4)}
S10 = \frac{1 - (1/2)sin(2\pi/ 4)tothepowerof10}{1 - (1/2)sin(2\pi/ 4)}
S10 = \frac{1 - (1/2)sin(\pi/ 2)tothepowerof10}{1 - (1/2)sin(\pi/ 2)}
S10 = \frac{1 - (1/2)(\sqrt{4}/2)tothepowerof10}{1 - (1/2)(\sqrt{4}/2)}
S10 = \frac{1 - (2/ 4)tothepowerof10}{1 - (2/ 4)}
S10 = \frac{1 - (1/2)tothepowerof10}{(1/2)}
S10 = 2 - \frac{1}{2^9}
Are you talking about sin^{10}(\pi/2) or sin((\pi/2)^{10})?
sin(\pi/2)= 1, but why in the world would you write that as "\sqrt{4}/2"?
I've seen some texts present the trig functions in this way as a mnemnonic device.
sin(0)= \sqrt{0}/2
sin(\pi/6)= \sqrt{1}/2
sin(\pi/4)= \sqrt{2}/2
sin(\pi/3)= \sqrt{3}/2
sin(\pi/2)= \sqrt{4}/2
The OP might have been referring to something like this, and didn't realize that \sqrt{4}/2 could and should be replaced with 1.
Based on the answer, I solved the question as sin((\pi/ 2)10).
As regards, expressing sin(\pi/ 4) as \frac{\sqrt{4}}{2}; yes, I was using the mnemonic but, as I indicated above, this is the first time I've dealt with these kinds of equations so I'll express it as 1, henceforth.
Thanks for helping, guys. I really do appreciate it.
