Summing divergences and the real projective line
  • Thread starter Thread starter japplepie
    Line
The discussion centers on the concept of the real projective line (RPL), which posits that positive and negative infinity are connected and indistinguishable. Participants explore methods for summing divergent series, particularly using algebraic techniques, leading to counterintuitive results such as j(2) equating to -1. This raises questions about the validity of traditional ordering and arithmetic when dealing with infinite sums, suggesting that conventional notions of greater than and less than may not apply. The conversation emphasizes the need for caution in interpreting results from manipulating divergent series, as they can challenge established mathematical principles. Ultimately, the RPL serves as a reminder that infinite operations can yield complex and often perplexing outcomes.
japplepie
The real projective line states that there is not difference between positive and negative infinity (maybe except the path needed to be taken to "reach" either one of them) and they are actually connected.
There are a lot of ways to get a definite sum from a divergent series; one of which is the algebraic way (my personal favorite).
note:j(x)=x^0+x^1+x^2+x^3+...
Using the algebraic method I could derive the sum of j(2) as shown below:
j(2)=1+2+4+8+16+...
j(2)=1+2j(2)
j(2)= -1= 1+2+4+8+16+...
Does this mean that j(2) diverges so much that it went pass infinity from the positive side and landed on a definite negative point?
If the statement above is true, then the idea of < and > falls apart.
Example:j(2)+j(1/2)-1=0 ( the extra -1 here is to account for the (1/2)^0 )
A sum of all positive numbers that equals 0.
A notion of < and > that would work in this scenario is by measuring how far it "moved" in the RPL.
j(2)+j(1/2)-1 "moved" and circled back to 0, but 0 never "moved".
j(4)=1+4+16+64+256+...
j(2)=1+2+4+8+16+32+64+128+256...=(1+2)+(4+8)+(16+32)+(64+128)+...
j(2)=3+12+48+192+...=3(1+4+16+64+...)
j(2)=3j(4)
S2:={1,2,4,8,16,32,64,128,...}
S4:={1,4,16,64,256,...}
S2\S4={2,8,32,128,...} which is S4 multiplied by 2 element-wise
S2-S4=2(S4) (treat it like a sum)
S2=3(S4)
Does this also mean that in j(x), the smaller x (x>=1), the bigger* it is.
Bigger* meaning it "moved" more.
Mathematics news on Phys.org
The real projective line is the one point compactification of the real line. It is a topological space, not a sentient being with the ability to communicate. It does not state anything.
In this space, there is no "positive" infinity or "negative" infinity. There are not two points to differentiate. There is one new point. Saying that this point is different from itself in some way is ridiculous.
j(2)=1+2+4+8+16+...
j(2)=1+2j(2)
This method assumes a lot of things about infinite sums; namely that this one in particular is a number and that all of the algebraic properties of finite addition and multiplication can be extended to infinite addition, whatever the hell that is. Since you haven't stipulated what infinite addition is nor why we should accept the aforementioned assumptions, there is no way to tell what your result "means".
Why? There are two very obvious linear orderings of the real projective line which extend the usual ordering on the reals.
Maybe you mean that this new ordering doesn't "play with" addition on the real projective line the same way the old ordering did on the real line. But regardless of where you put ∞ in this ordering, under the usual assignment of a+∞=∞ the theorems involving order and addition are still true.
So this is really about how your infinite addition interacts with the ordering. Again, until you tell us what infinite addition is, we can't confirm any observation regarding how the order is broken.
j(2)=3j(4)
S2=3(S4)
It means that the idea behind it states ...
And yes infinite operations are still very shady.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
