MATLAB Adding Signal and Shot Noise in MATLAB - MB's Question
The discussion centers on adding two vectors in MATLAB that represent signals with shot noise and determining the resulting signal-to-noise ratio (SNR). Participants highlight that the addition of two uncorrelated Gaussian noise sources typically follows the formula for combined noise, which involves the square root of the sum of the squares of the individual noise components. The importance of noise correlation and bias in measurements is also emphasized, as these factors can significantly affect the overall noise characteristics. Additionally, suggestions for further research include exploring Monte Carlo simulations and control theory related to Gaussian sums. Understanding the nuances of noise addition is crucial for accurately assessing SNR in applications like Raman spectroscopy.
evidenso
hello
well I have 2 vectors in MATLAB each representing a signal+shot noise. I have to add them. Can anyone tell me what the signal noise ratio will be when they are added?
thanks MB
evidenso said:
hello
thanks MB
If this is homework/coursework, I can move the thread to the Homework Help forums.
What are your thoughts on how to add signals and noise? What constraints can you place on the noise in these two signals? For example, is the noise correlated in any way between the two signals? Why would that be important?
No home assignment. I have to use it for investigating whether Raman SSRS degrades SNR :) but that's a whole other story for physicsians
I have to know if adding 2 noise sources gives more noise? let's say it is gaussian noise and I have 2 vectors with signal1 + noise1 and signal2+noise2
I recall it's something with 1/sqrt(2)(noise_1+noise_2) but I can't fint any material on the net.
That rule of thumb assumes a lot: Uncorrelated, unbiased, gaussian noise. berkeman already mentioned the issue of correlated noise. I'll add another: bias. If your measurements are consistently high (or low), taking a lot of measurements will not help address the measurement problem.
I'm not an expert on noise, so I'll let others chime in with better answers. But I did google adding noise sources rms, and got some good hits. Here's one hit from that search, centered more on on vibration noise, but with mathematical treatment that is more generally applicable:
http://www.techmfg.com/techbkgd/techbkgd_1.html
Dang. Modeling noise is one of the hats I wear. Unfortunately, I'm getting a lot of noise from my family about dinner.
Handling noise properly is not a simple topic. One can take graduate-level classes in which noise figures prominently. Some starters for google: Weiner filter, Kalman filter, recursive least squares filter, ...
summed noise = sqrt(noise1^2 + noise^2) if uncorrelated and Gaussian The approximation given can yield a total noise lower than each individual component, I wish it were that easy to get rid of noise.
What's the relative size of the two noise components? Since they add in quadrature the larger one often strongly dominates.
i can't give you a satisfactory answer because it's been too many years since i worked with it, but i think the noise distribution on your signal may actually be non-gaussian. i'd suggest you either try doing some monte carlo simulations to convince yourself of your intuition, or look up some control theory on gaussian sums. looking up your question on google seems to show there's a difference here depending on whether what you're looking at is actually a mixture or a sum.
