Supermesh analysis w/ dependent sources
  • Thread starter Thread starter rms5643
    Analysis Sources
The discussion focuses on using mesh analysis to solve a circuit problem involving dependent sources. Participants clarify the correct formulation of super mesh equations and source equations, emphasizing the importance of accurately defining current directions and voltage drops. There is confusion regarding the treatment of the dependent current source and its effect on the mesh equations, particularly in relation to the signs of the terms. The conversation also addresses the relationship between the currents and voltages in the circuit, specifically how to express W in terms of Y using Ohm's law. Ultimately, the participants work towards correcting their equations and understanding the implications of their assumptions in mesh analysis.
rms5643
Use mesh analysis to find the power delivered by the current-controlled voltage source in the circuit in the Figure: http://i.imgur.com/LUXYFO5.jpg
1 super mesh equation, 1 source equation, 1 mesh equation, KVL
To start off, I made all of my currents flow counter-clockwise and I labeled them, starting from the bottom left loop, then bottom right, then upper left, then upper right loop as: W, X, Y & Z, respectively.
Next, I drew a super mesh equation around Y and Z (Upper left and upper right). My super mesh equation:
6*Y-X+8*Z=0
Next, I wrote down my source equation:
3=Z-Y
Finally, I did a regular loop around X (Bottom right):
6*X+X+32*(X+W/8)=0 (Note, I added W/8 instead of subtracted because I defined all my currents to go counter-clockwise, except, the current coming from the voltage-controlled current source is going the opposite way, so it would technically be 32*(X-(-W/8)). I'm not sure if this assumption is correct. I think my mistake may be there.
Next, since W is an unknown, I need one more equation. Since W is defined as the voltage drop across the upper left resistor, I wrote the following:
W=6*Y
Now, here I am also unsure whether or not this is correct. Since Y is entering the negative terminal of the resistor, or at least I've defined it to be, would that make W=6*-Y?
So, my two questions are whether W/8 is positive or negative in 6*X+X+32*(X(+/-)W/8) and whether Y should be negative or positive in W=6*(+/-)Y. (As well as my mesh loops, not quite sure I completely have the hang of mesh analysis)
Thanks for all of your help again!
6*Y-X+8*Z=0
The 6Y is a voltage
The -X is a current http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon5.gif
The 8Z is a voltage. Why aren't these three terms all voltages?
The dependent voltage source has a gain of 15 volts/ampere. Therefore its voltage is 15X. Correct?
3=Z-Y
Right.
Hey Nascent, that was my error. I don't know why, but I kept ignoring the 15. My equations should be
Supermesh: 6*Y-15*X+8*Z=0
Source: 3=X-Y
Voltage-controlled current source: W=6*7
Bottom right mesh: 6*X+X+32*(X+W/8)=0
Do these look correct?
i) right
ii) no, it's 3=Z-Y
iii) how did you get 6*7
iv) wrong
W is not a voltage drop; W is a current. (EDIT: you noticed W = -Vx/8 but messed up when trying to use this. You have the right idea, but are making careless mistakes.)
Thanks for all your help Oxygen, I just noticed I switched up my loop variables when I redid some of the equations, namely ii), which should be 3=Z-Y
For iii), that should be W=Y*6
For iv) 6*X+15*X+32*(X-W/8)=0
Now, why is it 32*(X-W/8) and not plus? I defined my W current to go the opposite direction of X, but since I see the current source, don't I just make W negative? Or should I always just follow my loop direction designation and assume the math will work out in the end? (Just that W will be a negative value?)
When I solve the system, I get the following: (With 32*(X-W/8))
W=-19.972, X=-1.5079, Y=-3.398, Z=-0.3298
I think this should be:
6*X+15*X+32*(X-W)=0
The current in the 32Ω resistor is just X-W.
Please explain why W = Y*6
I assume this question is actually directed to rms5643 rather than to me.
Using Ohm's law V=IR, the voltage drop across the 6 ohm resistor is the current, Y, times the resistance, 6 ohms. I am attempting to use W as Vx in the figure and account for the 1/8 in my X mesh equation since it does not appear anywhere else.
Would it be more appropriate to assign W=(Y*6/8)?
It would be.
