Superposition and homogeneity - graph analysis
Superposition and homogeneity are concepts related to linear systems, where superposition refers to the principle that the response caused by multiple inputs is the sum of the responses from each input individually. In the context of the diode's current-voltage characteristic graph, the relationship is non-linear, which means it does not satisfy the properties of superposition. The user notes that using two test points shows differing slopes, indicating non-linearity. This confirms that the diode does not exhibit superposition or homogeneity. Understanding these concepts is crucial for analyzing the behavior of non-linear devices like diodes.
Matt1234
hi guys,
Can someone please help me understand superposition and homogeneity in regards to the following graph.
p-n-junction-diode-v-i-characteristics.jpe
(current voltage characteristic of a diode)
To be honest i don't understand the terms. The exact question I am asked is Use two test points on Graph to show if the diode satisfies the properties of superposition and homogeneity.
Unfortunately i don't know what either of those are, can someone elaborate?
Thank you for your time.
I have found that superposition depends on linearity. In this case the relationship does not satisfy the properties of superposition. Can someone confirm? Also would it suffice to take slope with different points and since the slope is not the same I can conclude ita non linear ?
Bump please
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
