Superposition of harmonic oscillations
The discussion focuses on finding the amplitude and phase shift of two superposed harmonic oscillations, specifically x1(t)=3sin(2∏t+∏/4) and x2(t)=3cos(2∏t). Participants clarify that the sine function can be converted to a cosine function with a phase shift, specifically changing 3sin(2∏t+∏/4) to 3cos(2∏t-∏/4). The formula for calculating the resultant amplitude, A=√(A1²+A2²+2A1A2cos(θ2-θ1)), is derived from the cosine law and can be visualized using phasor representation. The discussion also emphasizes the importance of adding the two functions as vectors to find the resultant amplitude and phase. Overall, the conversion and vector addition methods are key to solving the problem effectively.
Lengalicious
Find the amplitude and phase shift of the following two superposed harmonic oscillations.
x1(t)=3sin(2∏t+∏/4)
x2(t)=3cos(2∏t)
Ok normally i would be able to do this, however one oscillation is cos and the other sin, so i can't use the trig identity for sin+sin or cos+cos. Is it possible to turn 3sin(2∏t+∏/4) into 3cos(2∏t+∏/4+∏/2) or is that invalid?
x1(t)=3sin(2∏t+∏/4)
x2(t)=3cos(2∏t)
I think you mean -π/2 there, but otherwise yep, that's fine. (Or there are similar trig identities you could use, but of course it will add up to the same thing.)
Yeh -∏/2 is what i meant, one more question when calculating the amplitude i find that somehow the following equation is derived, A=√(A12+A22+2A1A2cos(θ21)). I don't understand how this is found?
Bump: How do I find the amplitude, i get a phase of pi/8 and an amplitude of 5.5 but i think my amplitude is wrong, can someone check please?
The formula above is an application of the cosine law. You can see how it applies if you consider that since both have the same frequency ##(2\pi)##, the two functions can be represented in phasor form and added as phasors.
Convert the first sin function to cosine as you have suggested previously. That makes its phase angle ##-\pi/4##. Its phasor is then a vector of length 3 with angle ##-\pi/4## from the x-axis. The second function has no phase, so it's a vector of length 3 on the x-axis. Add as you would any two vectors. You'll find that one way to find the magnitude is to apply the cosine law -- draw it, you'll see. You could also add them via the component method. Either works just fine.
Ah, that helps a lot thanks very much
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
