Superposition of position functions
The discussion centers on the principle of superposition in physics, specifically regarding the position functions of a body subjected to two forces, F_1 and F_2. When only one force acts on the body, the position is described by r_1(t) or r_2(t) for F_1 and F_2, respectively. The question posed is whether the combined effect of both forces can be expressed as r_c = r_1 + r_2. It is noted that while the principle of superposition applies in many scenarios, it fails in cases involving rigid body rotation, nonlinear optics, and fluid flow. Ultimately, the principle holds true only in linear systems, as non-linear conditions invalidate the relation.
rohanprabhu
If I have two forces, F_1 and F_2, such that, if a body 'a' is applied only one of the two forces, either F_1 and F_2 for a given experiment and it is determined that.. if only F_1 acts on 'a', then the position of 'a' is given by: r_1(t) where 'r_1' is a position vector as a function of time and if only F_1 acts on 'a', then the position of 'a' is given by r_2(t), where 'r_2' is a position vector as a function of time.
Now, the body is subjected to both the forces F_1 and F_2 and the position of 'a' is given is by r_c. Then, does this relation hold true:
<br /> r_c = r_1 + r_2<br />
Science news on Phys.org
Surely that is not always the case: rigid body rotation, nonlinear optics, fluid flow...
Yes, the principle of superposition is applicable in this case. Of course, once your system becomes non-linear, then it no longer holds.
Claude.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
