Superselection rules and non-observable Hermitian operators
ShayanJ
Insights Author
Its usually said(like https://en.wikipedia.org/wiki/Superselectiond ) that superselection rules imply that not all Hermitian operators can be considered to be physical observables. But I don't understand how that follows. Can someone explain?
Thanks
Superselection means that some form of physical constraint is imposed on the general structure of observables on the Hilbert space.
As an example, the geometry of spacetime implies that rotating a system by one full cycle must not change any properties of the system. The double cover representations in quantum theory however may introduce a phase shift upon such an operation.
Fermions and Bosons will therefore be out of phase after such a rotation has been performed. Since nothing observable (in the future or the past) may change, the Hamiltonian, and with it all measurable quantities, may not depend on any phase difference between a Fermionic and a Bosonic component of the state. The two realisations of the permutation group are therefore said to live in separate superselection sectors. The observable operators then separate into a direct sum of operators on each sector.
Hoper this helps!
Jazz
Likes ShayanJ
So it implies that any operator which can't be decomposed that way, should not represent an observable. Right?
Yes.
You can put it also a bit differently and say a superselection rule constrains the possible superpositions of states. One example is the "spin selection rule". In usual quantum theory you cannot make superpositions of a state with half-integer and integer spin. Suppose you do so, i.e., having, e.g., ##s_1=1/2## and ##s_2=0## and consider the state
$$|\psi \rangle=|1/2,-1/2 \rangle+|1,-1 \rangle,$$
then the rotation around the ##z## axis by ##2 \pi## does not give ##\exp(\mathrm{i} \varphi) |\psi \rangle## for any real ##\varphi##.
Then of course you have a restriction on the possible operators, representing observables, particularly the Hamiltonian: Such an operator must not mix any half-integer spin state with an integer-spin state and vice versa.
Likes ShayanJ
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
