Supporting spring, object, top spring problem.
  • Thread starter Thread starter mechdesignron
    Spring
The discussion revolves around a spring system where an object is supported by two sets of springs, with the goal of determining how far the object will fall (delta) when a weight (FW) is applied. The initial formula presented for delta was found to be incorrect, as increasing the compressed distance of a spring does not increase its stiffness, according to Hooke's Law. Instead, the correct relationship shows that the distance the object drops is solely dependent on the spring constants (k1, k2) and the weight (FW), not on the preload compression. The clarification of terms such as N1 and N2, and the definition of delta, helped refine the understanding of the system. Ultimately, the conclusion is that the drop distance is influenced only by the spring constants and the applied weight.
mechdesignron
FW+(Spring Force 2)K2N2(D2-Delta)
(spring force 1)K1N1(D1+Delta)
I have a spring set(springs in parallel) on top of an object and a spring set supporting the object. The weight of the object is represented by FW. The bottom springs are F1 and the top springs F2. There is preload on the springs, represented by D1 & D2 repectively. I want to know how far the object will fall (Delta) in the given system.
I came up with this formula.
FW+K2N2(D2-delta)=K1N1(D1+delta)
Some magic algebra and Presto:
delta=(FW+K2*N2*D2-K1*N1*D1)/(K1*N1+K2*N2)
OK my problem. It doesn't seem to work. I plugged this into my handy-dandy spreadsheet and when I change the K value-keeping them both the same- it works fine. The higher the K the less the object falls. but when I change the compressed distance -keeping them both the same-, (which should, by hooks Law make the spring stiffer), does not change the distance the object moves. Please help.
Thank you
Clarify a couple of points, please.
What are N1 and N2?
What do you mean by "fall"?
What is delta?
How did you arrive at your equation? It might be a good idea if you would put your full development process in a post so that I can see how you got here.
mechdesignron: Assuming no coils touch, increasing the compressed distance of a linear elastic spring does not increase its stiffness. Instead, by Hooke's law, the force on the spring increases, not its stiffness.
I will call the spring constants of your two spring sets k1 and k2. Although you do not say what N1 and N2 are, we see from your formulation that k1 = K1*N1, and k2 = K2*N2. The equation in the middle of your post is correct. However, we know from equilibrium before Fw is added, k1*D1 = k2*D2. Substituting this into your middle equation, the equation simplifies to Fw - k2*delta = k1*delta. Solving for delta gives delta = Fw/(k1 + k2), which is exactly the result expected. In other words, no amount of preload compression (if your spring coils do not touch) changes the distance an added object drops (delta). The only way to change the distance the object drops is by changing k1, k2, and/or Fw. Your observed results are correct.
Thank You nvn
It looks like nvn has awnsered my question but I will clarify to both clean up the post.
The top "equation" is an attempt at a free body diagram with the underline representing the supported object. N=number of springs, by fall I mean delta (the amount an object moves).
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
