Where Can I Find Practice Kits for Surface Mount Drag Soldering?
Practice kits for surface mount drag soldering can be found at various online retailers. Recommended sources include EMPF, which offers electronics manufacturing training kits, and CircuitMedic, which provides specific practice products. Additionally, searching for "IPC solder training kit" can yield more options for suitable materials. These resources allow users to practice without risking damage to expensive components. Utilizing these kits can enhance soldering skills effectively.
JerryG
Do you guys know where I can buy some dummy parts and boards that I can practice drag soldering with? I would like to give it a try, but I don't want to ruin expensive working components.
Here are some kits:
http://www.empf.org/cart/electronics-manufacturing-training-kits-c-21.html
http://www.circuitmedic.com/products/practice.shtml
searches for things like ipc solder training kit should turn up more.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
