Surface Runoff - Explained and Debated
High surface drainage leads to reduced surface runoff because well-drained surfaces absorb more water, leaving less available to flow over the land. The discussion clarifies that "surface drainage" and "drainage density" are distinct concepts, with drainage density referring to the length of channels that carry runoff per unit area. A porous, well-drained surface results in lower runoff potential, while poorly-drained surfaces lead to higher runoff due to water's inability to infiltrate. The relationship between drainage characteristics and runoff is crucial for understanding water flow in natural systems. Overall, effective drainage management is essential for controlling surface runoff.
fonseh
In my book , i was told that when the drainage of surface is high then the surface runoff will be low . However , i don't think it's correct .
Definiton : Runoff can be described as the part of the water cycle that flows over land as surface water instead of being absorbed into groundwater or evaporating.
[/B]
I think that when the surface drainage is high , more water will be drained from the particular surface to another . This results in more water absorbed , resulting in higher surface runoff , correct me if i am wrong .
You have not given much context here. Are you modelling rain water flow over soil?
The exact wording is very important.
If the drainage into a surface is high, then there will be less to run off that surface onto another.
Likes Merlin3189 and fonseh
why ?
here it is
Assuming natural ground with no pumping systems then any water flowing into a particular region can only do one of four things - accumulate , evaporate , soak in or run off to somewhere else .
Likes CWatters and Merlin3189
The term Drainage is being used in two different ways.
"Surface drainage density" is a different concept to "surface drainage". They are in effect perpendicular.
Well-drained or poorly-drained is being used to describe the ability of a surface to absorb water vertically into a porous surface.
"Drainage density" is defined as the length of horizontal surface channel per unit area that carry runoff.
A well-drained surface is porous. Because it absorbs water, there is less water available to runoff and so there are less surface channels needed, which implies a lower surface drainage density is needed.
Likes CWatters, fonseh and BvU
+1
Wikipedia defines "Drainage Density" as..
..the total length of all the streams and rivers in a drainage basin divided by the total area of the drainage basin.
"Well drained material (porus) has a lower run-off potential" .- eg the water soaks into the ground therefore fewer rivers and streams form so drainage density is low
"Poorly-drained material (non-porus) has a higher run-off potential" ... the water runs off because it can't soak into the ground. Therefore more rivers and streams are formed so drainage density is high.
Likes fonseh
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 45 ·
