Surface temperature of a radiated plate
The surface temperature of a material radiated from another depends on factors like color, material type, and distance between the plates. In this scenario, with a 120°C aluminum plate facing another aluminum plate at 10cm distance, the exact temperature of the second plate can be influenced by emissivity and absorption characteristics. The discussion highlights the importance of considering radiation exchange between the plates, noting that smaller plates may not fully exchange radiation. Additionally, the hot plate is maintained at 120°C indefinitely, complicating the analysis of heat transfer. A mathematical formulation is sought to better understand the thermal dynamics in this setup.
marco75
Hi,
I would like to know what is the surface temperature of a material when it is radiated from another material at a certain distance. In other words: I have a material at 120°C (aluminium) and another parallel plate of area A faced to the first one at 10cm of distance. What is the surface temperature of the faced material?
This problem is general, so all data (emissivity, room temperature, etc.) are free, I would like to have a conceptual response, my numerical data are only to example purposes.
Thank in advance
Science news on Phys.org
the surface temp would depend on at least its colour and type of material
if it was a darker colour then it would absorb more energy and get hotter
think of a white car to a black car in the summer sun
other factors would also come into play
Dave
Hi davenn,
many thanks for the answer. Yes, I understand what you say, but I would like to know a mathematical formulation, so we can suppose aluminium for both materials and choose some reflectivity, absorption and transmission values (I don't know if the correct analysis is obtained by means of the Kirchhoff law (thermal...)).
Marco
Is all of the radiation from each plate being exchanged between the 2 plates?
For smaller plates not so, as some radiation from each will bypass and not strike the other.
An assumption of infinite plates can be made, if the separation distance is much smaller than the area of the plates.
See
http://www.chem.mtu.edu/~fmorriso/cm310/heat_lecture_20.pdf
Is the 120 degree plate kept at that temperature indefinitely, or does it cool as it radiates its heat away?
Hi 256bits and Matterwave,
thank you for the answers. The hot plate remain at 120°C indefinitely and the assumption of infinite plates cannot be made, because we have the following schema: an heater at 120°C has a size of 14cm x 7cm (hot plate) is faced to another aluminium plate (same size) at a distance of 10cm.
Thanks again,
Marco
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
