System of linear inequalities to find a vector
The discussion revolves around a system of linear inequalities in three dimensions, specifically aimed at identifying a vector within a defined set that has the maximal length. The inequalities define a feasible region in R^3, which is described as a convex polyhedron.
  • Participants discuss the transformation of the inequalities into matrix form and the subsequent solution using Gauss elimination. There is a focus on the interpretation of the solution as a point of intersection of planes defined by the inequalities.
  • Questions arise regarding the method of finding the vector with maximum length, particularly in relation to the properties of convex functions and extreme points within the feasible region.
Participants are exploring the implications of the original poster's solution and questioning its validity in the context of maximizing the length of the vector. Some guidance is provided regarding the nature of convex optimization and the need to evaluate multiple corner points of the polyhedron.
There is an acknowledgment of the complexity of the problem, including the potential for multiple local optima and the need to consider various corner points to determine the maximum length. The discussion also highlights the instructor's feedback on the original approach taken by the poster.
FightingWizard
Let P be the set of (x,y,z)^t in R^3, which satisfies the following inequalities:
-2x+y+z <=4
x-2y+z<=1
2x+2y-z<=5
x>=1
y>=2
z>=3
I want to find the vector in the set with the maximal length.
I have transformed the linear inequalities into matrix form:
(2 -1 -1 -4)
(-1 2 -1 -1)
(-2 -2 1 -5)
I solved it using Gauss elimination and got x = 2, y = 3 and z = 5, which satisfies the linear inequalities.
To find the length of the vector I did : sqr(2^2+3^2+5^2) = sqrt(38), which was my answer.
My instructor says that my solution is not correct. Can anyone help me?
For each inequality, if you consider it as an equality instead, it specifies a plane. Hence the problem specifies six planes, which will form the boundary of a (probably irregular) polyhedron that is the set of possible points.
What you have done by solving that system of equations is find the point that is the intersections of the first three planes. There is no reason to expect that that point will be the one whose position vector has maximum length.
How do I then find the vector with the maximum length in the polyhedron?
-2x+y+z <=4
x-2y+z<=1
2x+2y-z<=5
x>=1
y>=2
z>=3
(2 -1 -1 -4)
(-1 2 -1 -1)
(-2 -2 1 -5)
Your inequalities imply that the feasible region in ##R^3## is a convex polyhedron. If you maximize the squared length ##x^2+y^2+z^2## (which will give you the same ##(x,y,z)## solution as the length itself), you see that you have a so-called convex function which is to be maximized over a convex polyhedron. There is a theorem about problems like that (convex maximization): an optimal solution occurs at a so-called "extreme point" of the feasible region, that is, at a corner point. The point you gave is, in fact, one of the corners, but there are several others. In principle, problems like yours can (and very often do) have numerous local optima, so in the worst case you would need to check the objective value (the squared length) at all the corners and then pick the one with the highest value. Intuitively, though, in your case you are trying to find the corner that is farthest from the origin, so that will cut down on a lot of the work. (Note: if you had been seeking a minimum instead of a maximum the problem would not have numerous local minima, and so there would be no need to enumerate lots of cases.)
I do think your answer is right. However, maybe the teacher objects to the method you used, which is quite naive and not at all rigorous (although, to be fair, it can be fixed up if you do a bit more work).
Your problem is a so-called Quadratic Programming Problem; see, eg.,
https://en.wikipedia.org/wiki/Quadratic_programming .
