System of 4 Pendulums: Why Don't They Move Faster?
  • Thread starter Thread starter teken894
    System
In a system of four identical pendulums, when potential energy is applied to one or two pendulums, the resulting motion raises questions about speed and energy conservation. When one pendulum is released, it moves, but when two are released, they move together instead of one moving faster. The discussion highlights that it is impossible to conserve both momentum and energy if only one pendulum moves after a collision. The mathematical analysis shows that the conditions for momentum and energy conservation cannot be satisfied simultaneously if only one mass is in motion. This illustrates the fundamental principles governing pendulum dynamics and collision outcomes.
teken894
In a system of 4 same-mass pendulums, when give potential energy to a pendulum (by raising it) and letting go, one pendulum on the other side moves equally...
When two are raised and let go, two pendulums will move after the collision...
why doesn't one pendulum move with twice the speed, rather than two pendulums moving?
Isn't it that two pendulums moving slower is the same as one pendulum moving faster?Hope I have made my wording sufficiently clear...
That's the kind of system I'm referring to
It is not possible to conserve both momentum and energy if only one mass moves after the collision.
Suppose the two masses arrive with speed v and the single mass leaves with speed u. Then momentum conservation requires 2v = u but energy conservation requires u^2 = 2 v^2 which is possible only if v = 0 or 1 = 2.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
