Using the Chinese Remainder Theorem to Solve Systems of Linear Congruences
  • Thread starter Thread starter oliver$
    Linear Systems
The discussion revolves around solving a system of linear congruences using the Chinese Remainder Theorem (CRT). Participants confirm the reduction of the original equations to simpler congruences, specifically x ≡ -3 (mod 10), x ≡ 12 (mod 35), and x ≡ 4 (mod 5). Different participants arrive at solutions, with one finding x = 47 and another concluding x ≡ 2 (mod 35). The conversation emphasizes the importance of correctly applying the CRT to derive solutions from the reduced congruences. Ultimately, the solutions are expressed in terms of a parameter, indicating multiple valid results based on the congruences.
oliver$
ok, am i doing this right?
here's the system:
3x== 1 (mod 10)
4x== 3 (mod 5)
3x== 1 (mod 35)
(3,10), (4,5), (3,35) all are 1.
it reduces to:
x== -3 (mod 10)
x== 12 (mod 35)
x== 4 (mod 5)
and then i use the CRT to solve this system? is that right?
here's the system:
3x== 1 (mod 10)
4x== 3 (mod 5)
3x== 1 (mod 35)
it reduces to:
x== -3 (mod 10)
x== 12 (mod 35)
x== 4 (mod 5)
I found x=47.What did u find??
Daniel.
i got x== 2(mod 35).
ok, so from
x== 7 (mod 10)
x== 2 (mod 5)
x== 12 (mod 35)
i got:
7 + 10t== 12 (mod 35), which reduces
10t==5 (mod 35)
(10, 35)= 5
10r + 35s = 5
r=-3, s= 1
(-3)(5)/5 = -5
t= -5 (mod 7)== 2 (mod 7)
t= 2 + 7l == 2 (mod 5)
7l== 0 (mod 5)
(7,5)= 1
7r + 5s=0
r=0 s=0
x= 0 (mod 5)
l=5m
x= 7 (5m) +2= 35m +2
or x== 2 (mod 35)
oliver$ said:
ok, so from
x== 7 (mod 10)
x== 2 (mod 5)
x== 12 (mod 35)
Here's how i see it:
x==7(mod 10)=>x=10a+7,a={0,1,...}(1)
x==2(mod 5)=>x=5b+2,b={0,1,...}(2)
x==12(mod 35)=>x=35c+12,c={0,1,...}(3)
You want to find "x" and hence "a","b","c".
From (1) and (2)=>b=2a+1,a={0,1,...}(4)
From (1) and (3)=>a=(7c+1)/2,c={1,3,5,...}(5)
From (4) and (5)=>b=7c+2,c={1,3,5,...}(6)
From (3),(5) and (6) u can write the solution to the problem
x=35c+12(7)
,where "c" can take only positive odd values (eq.(5)/(6)).
So x\in\{47,117,187,...\}
Daniel.
PS.I solved the problem in the positive numbers set,for the set of integers it can be generalized straightforwardly.
