Is there a way to prevent T1 stress tests from keying all radios at once?
  • Thread starter Thread starter gtacs
    Circuit Device
The discussion centers on the challenge of T1 stress tests inadvertently keying all radios simultaneously due to the nature of the T1 signal used for communication. The user seeks a solution to filter out the specific T1 signal that triggers this issue while allowing other valid signals to pass through. Suggestions include examining the T1 multiplexer (mux) settings, as some systems can be configured to handle "all ones" conditions without activating the keying mechanism. There is a consensus that a specialized filter or adjustment at the mux level may be necessary to prevent the undesired keying of radios during stress tests. Addressing this issue is crucial for maintaining operational integrity during T1 line testing.
gtacs
I work in the electronics industry on radio communications specifically. The radios I maintain are not usually located at the facility in which they are used. Meaning the tramsmitters and receivers are located several miles from their respective operators, and the audio signals as well as the push-to-talk signalling are transmitted back and forth (from the operators to the tramsmitter/receiver facility) via a T1 line. A busy signal, or "high" on the T1 line is what we use to key the transmitters.
The problem i am experiencing is when we have a T1 problem, or the local telephone company needs to do checks on the line, they run what is known as a "Stress Test" which is a properly "framed" T1 signal with all "highs". This is meant to stess the line to its max potential and the phone technicians use this data to evaluate the line.
As you can see the problem is when they run this test, it will key all the radios in the facility. This is mainly an issue when the testing is done without the radio technician's knowledge, or someone is unaware that this will happen.
I am in need of a circuit or device that will accept a T1 input (from a RJ-45 connector) and pass all valid inputs EXCEPT the properly framed T1 with all "highs", there is never a scenario in which we would want all the radios keyed at once.
Thanks in advance for your help
What is radio keying?
So you need a filter that takes an RJ-45 copper input and outputs the same? That filter needs to filter out only properly framed T1 with all highs?
Can you provide some more information about this T1 "high" signal?
I would think the solution to your problem would be at your T1 mux that interfaces to your radio transmitter. I believe that where I work we have a simular set up and key in the same way. When we get an all ones condition though, the mux goes into an alarm, but does not assert an "E" keying lead. Maybe you should look at your mux documentation as there might be a setting for how it handles an "all ones" condition.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
