Take the natural log of both sides?
The discussion revolves around finding the first derivative of the function y = x^(e^x) using logarithmic differentiation. Participants confirm that taking the natural log of both sides is an appropriate method, leading to ln(y) = e^x ln(x). Differentiation is performed using implicit differentiation and the chain rule, resulting in a formula for dy/dx that includes both e^x and ln(x). There is a debate about whether to simplify further or replace y with its original expression to achieve the final answer. The conversation highlights the validity of multiple approaches to arrive at the same derivative result.
tony873004
Find the first derivitive. Simplify if possible (factor).
<br /> \begin{array}{l}<br /> y = x^{e^x } \\ <br /> \\ <br /> \ln y = \ln x^{e^x } \\ <br /> \\ <br /> \ln y = e^x \ln x \\ <br /> \end{array}<br />
There's a similar problem in my class notes where it was solved by taking the natural log of both sides. Is this the way to go on this problem? If so, I'm stuck at this point.
Can't you just use the chain rule?
You're doing just fine...differentiat both sides to get
<br /> \frac{1}{y} \frac{dy}{dx} = e^xln(x)+e^x/x<br />
Then go from there...
As Geekster said, you can use implicit differentiation. Personally, I'd just use chain rule.
y = x^{e^x} = e^{(e^x)(\ln x)}
This is of the form y = e^{f(x)} the derivative of which is
y&#039; = f&#039;(x)e^{f(x)}
So
y&#039; = (\frac{1}{x}e^x + (e^x)(\ln x))(e^{(e^x)(\ln x)})
which you can simplify.
re: geekster
Thanks. I got that far. Should I just multiply both sides by y? But that would leave me with <br /> \frac{{dy}}{{dx}} = e^x y\ln x + \frac{1}{x}y<br />
Don't I need to get rid of y on the right side?
re: Curious3141
Thanks.
This was on the test for implicit differentiation. Chain rule was last test, but he didn't say we couldn't use it. Give me a little while to see if I can simplify that, and I'll post what I get.
tony873004 said:
re: geekster
No...you were given y in the problem. Just replace y by x^e^x and you get the same answer that Curious3141 gave. I think it's good to see the same answer can come from many different methods. Although Curious3141's method is more elegant IMO.
is this how u do it..?
