Can a parabolic surface help reduce heat from sunlight?
  • Thread starter Thread starter Robin07
    Heat Sunlight
The discussion revolves around the use of a parabolic surface to reflect sunlight towards a PV cell while minimizing heat. Participants clarify that infrared radiation, often associated with heat, can be reflected or transmitted differently depending on the surface treatment of mirrors. The concept of "one-way" mirrors is debated, with emphasis on the need for specific filters that allow visible light while blocking infrared to reduce heating effects on the PV cell. Suggestions include using cold mirrors to separate useful light from unwanted infrared radiation, although concerns about cost-effectiveness are raised. Ultimately, understanding the wavelengths that the PV cell can utilize is crucial for optimizing energy production without excessive heat.
Robin07
If I should reflect our suns' rays off of a parabolic surface, and placed a one way mirror at a distance away, short of the focus point. Let's say a 10cm disk is placed at that point parallel to the parabolic rim. The light would tend to reflect back at the parabolic surface but would the majority of the heat that is also refracted/reflected back to the parabolic surface be cool?
Thanks
Science news on Phys.org
Robin07 said:
...but would the majority of the heat that is also refracted/reflected back to the parabolic surface be cool?
That doesn't make any sense. How can heat be cool? Perhaps you could reword the question...
yes the heat is reflected with the light...that's where the power resides...
It sounds like "heat" means infrared radiation here. It all depends if the mirror reflects infrared radiation or not.
p.s.
Infrared radiation is not really the same as heat, though it can be converted to heat upon absorption. For that matter, the same is true of visible light or any part of the electromagnetic spectrum.
Redbelly98 said:
It sounds like "heat" means infrared radiation here. It all depends if the mirror reflects infrared radiation or not.[/I].
Interesting, so what type of suface treatment is needed to have the infrared radiation go through a one way mirror? Are there one way infrared morrors on the market?
What I'm trying to do is relfect light minimizing heat and have more light hit a small surface, a PV cell 50mmx50mm square in this case. The suns rays hitting a 50x50 PV cell will, in my case produce 1/2V @ 180ma. If I concentrate more light on it, it should do better but I will need to disapate the heat.
Thanks again
You'd probably be better off checking the specifications for your PV cell to see what wavelengths (or frequencies) of radiation will make it produce power, and then looking for a filter that blocks everything else. For all you know (well, for all I know), the cell might produce power just as well from infrared radiation as it does from visible light, and in that case if you block the infrared light you're just wasting useful energy.
Is there really such a thing as a "one-way" mirror?
No. That's a misnomer.
The "one-way" effect comes about from it being much darker on one side than the other.
Hi there,
Infrared radiation is the same as visible light, just with a longer wave length. Therefore, if infrared radiation can be considered as heat, so does visible light.
In this case, heat should not be the word use. Since heat refers to transfer of energy between two body.
Cheers
If this is a typical silicon PV cell, it will absorb wavelengths shorter than 1.1 μm. Not sure offhand what fraction of the sun's energy this is.
From eyeballing the red area in this graph, looks like about 75-80% of the solar spectrum is less than the 1.1 μm cutoff of a silicon PV cell.
While rejecting the 25% or so unusable part of the spectrum could offer some heat reduction, one has to consider if it is worth the expense.
A question I have is, to what extent are the longer wavelengths absorbed and heat the cell? Or is silicon simply transparent there? If that's the case, then there really is no need to worry about heating by the longer wavelengths.
EDIT: the above graph is from here:
http://en.wikipedia.org/wiki/Solar_radiation#Composition
I found this on:
http://en.wikipedia.org/wiki/One_way_mirror#Unusual_types_of_mirror Quote:
"Cold mirrors are dielectric mirrors that reflect the entire visible light spectrum while efficiently transmitting infrared wavelengths. Conversely, hot mirrors reflect infrared light while allowing visible light to pass. These can be used to separate useful light from unneeded infrared to reduce heating of components in an optical device."
It looks like I'm looking for a cold mirror. Does anyone know where I can get a hold of a cold mirror?
Thanks again
If you just want to prevent infrared light from reaching the PV cell then it would seem like your best bet would be something which is transparent to visible light and opaque to infrared. However, as has been said infrared light is no more so heat than any other wavelength, including visible light. Blocking infrared will just lessen the amount of power the PV generates, you might as well just put shades on it.
Note that in your quote above it says those mirrors are useful to block unused light from optical devices. A PV cell is not an optical device. Ideally you would want to find out what wavelengths your PV cell uses (it likely uses infrared) and block the rest. I doubt though that it would be worth the cost to do this.
Well, if you can find the maximum wavelength your solar cell can turn into electricity and if that wavelength matches with the cutoff frequency of some material (ie, ordinary window glass...?), you could just put such a thing up above the solar panel.
But I suspect the reason you don't see this being done is that the cost outweighs the benefit.
Could someone tell me a good way of creating an inexpensive filter that attenuates UV radiation to around 1/10,000 but affects visible light only by a tenth. I need this as a sheet which I have to place on a sensor. And the given budget is $5.
Er... any polycarbonate clear plastic is a good UV attenuator. Even ordinary clear glass absorbs almost all of the UV.
P.S. You really should start a new thread since this is off-topic to the current thread.
Zz.
