Tangent plane of a parametric function
BiGyElLoWhAt
Ok, so I'm really hoping someone can help me logic my way through this.
I have a function to the effect of: ##r(u,v)=f(u,v)\hat{i} + g(u,v)\hat{j} +h(u,v)\hat{k}##
I need to find an equation of a tangent plane at a point ##(u_{0},v_{0})##
and quite frankly I'm at a loss on how to do this.
So what I ultimately want is 2 vectors tangent to the surface at that point, I'm not sure that with what I have I can simply chain some derivatives together and cross them...
If I had z(x,y) I would simply take ##\frac{\partial z}{\partial x} (cross) \frac{\partial z}{\partial y}## as that would give me 2 (presumably different) vectors and crossing them will give me my normal to use in my tangent function...
Now how to apply this to a parametric function in 3-space...
Ok... I think I just answered my question as I was typing this... (It happens that way quite a bit)
##\frac{\partial r}{\partial u} (cross) \frac{\partial r}{\partial v}##
But what if I had ##r(u,v,w)## ?
In my head , whether I chose to cross
or
##\frac{\partial r}{\partial u} (cross) \frac{\partial r}{\partial w}##
or
##\frac{\partial r}{\partial w} (cross) \frac{\partial r}{\partial v}##
It really shouldn't matter, I guess at this point I just want to hear somebody's input other than my own. All of these will give me a normal, no?
(once I plug in my point that is...)
A surface only has two parameters. So you will only run into the ##r_u\times r_v## case for a surface. And you are correct, that is how you find a normal.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
