Find Tangential Velocity of Star: "k" Conversion Factor Explained
To find the tangential velocity of a star, the formula Vt = μ × d is used, where Vt is the tangential velocity, μ is the proper motion in radians per second, and d is the distance in meters. The proper motion must be converted from arcseconds per year to radians per second, which requires knowing the conversion factors for these units. The discussion highlights the importance of accurately converting these values and understanding the role of the conversion factor "k" in the formula for tangential velocity. Additionally, it emphasizes the need for a systematic approach to unit conversion for accurate results. Proper conversion is crucial for determining the star's tangential velocity correctly.
JoAstro
I am trying to find the tangential velocity of a star but I am confused with the whole procedure.
[/B]
They give me the following data:
⋅Distance: 32parsecs
⋅μ: 0.24 arc seconds per year
I have a section explaining proper motion that states the following formula:
Vt= μ⋅d
where Vt is the tangential velocity expressed in SI units, μ the proper motion in arc seconds per year expressed in radiants per second, and d the distance expressed in SI units.
d= 32pc = 9.87×1017metres
μ= 0.24 = 1.16×10-16rad/s
(I used google to convert these values)
Thus,
Vt = μ⋅d = (1.16×10-16 rad/s) × (9.87×1017 m.)
Vt = 114.49 m/s
But I am not 100% sure with my method and therefore my final result.
Then, I decided to read a little further and I stumbled upon a website that explained the tangential velocity in a more "complete" or rather different way. It said:
***To get the tangential velocity, you need to first measure the angular velocity of the star across the sky (d[PLAIN]http://www.astronomynotes.com/starprop/theta.gif/[I]dt[/I]). This is how many degrees on the sky the star moves in a given amount of time and is called the proper motion by astronomers. If you determine the star's distance from its trigonometric parallax or the inverse square law method, you can convert the angular velocity (proper motion) to tangential velocity in physical units such as kilometers/second. The tangential velocity = k × the star's distance × the proper motion, where k is a conversion factor that will take care of the conversion from arc seconds and parsecs and years to kilometers/second. Using the Pythagorean theorem for right triangles, you find that the star's total velocity = Sqrt[(radial velocity)2 + (tangential velocity)2].
My question is, what is that "k" they mention being the conversion factor?
This is not correct. Note that μ is given in arcseconds per year. Also, make sure you are converting arcseconds to radians correctly.
TSny, thanks for pointing that out.
I used google as I don't know a way to go at it. May I ask if you know how to convert these values? :)
You must have misread the 10-16 factor when using Google.
To do the conversion yourself, you will need to know how many radians are in one arcsecond (or vice versa) and you will need to know how many seconds are in a year. Then use a standard systematic method to convert arcseconds/year to radians/second. If you need a refresher on converting units, try https://www.mathsisfun.com/measure/unit-conversion-method.html or search for some other sites.
Definitely need that refresh!
Thank you :)
12K
