Taylor series Mostly conceptual
trajan22
I was just curious why when doing a taylor series like xe^(-x^3) we must first find the series of e^x then basically work it from there, why can't we instead do it directly by taking the derivatives of xe^(-x^3). But doing it that way doesn't give a working taylor series why is this so?
You can do it either way. But the derivatives of xe^(-x^3) get complicated pretty fast. So you may just be doing it wrong. I probably would. It's just a question of choosing the easiest method.
Oh ok I see. I was looking at the wrong answer, I think. Thanks though
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
