JasonWhat is the Taylor series for ln(x+2) about x = 0?
zzmanzz
Using power series, expand ln(x + 2) about a = 0 (Taylor series)
Is this appropriate?
ln(x+2) = ln((x+1)+1)
x' = x+1
ln(x'+1) = \sum_{n=0}^{\inf} \frac{(-1)^n}{n+1}(x')^{n+1}
or
ln(x+2) = ln(\frac{x}{2}+1)
x' = \frac{1}{2}x
Well, you rather have
\ln(2+x)=\ln[2(1+x/2)].
You can, however still use your trick with this correction made!
So would your formula then be:
ln2 + ln(1+(x/2)) = ln2 + \sum_{n=0}^{\inf} \frac{(-1)^n}{n+1}(x/2)^{n+1}
or
ln(2(x/2+1)) = 2*\sum_{n=0}^{\inf} \frac{(-1)^n}{n+1}(x/2)^{n+1}
This you should be able to answer yourself by giving the reasoning behind each of the two claims you made. Of course only one of them can be right!
I believe that the first one is right because
ln(AB) = lnA + lnB
A = 2, B = (1+x/2)
I think you want to do the expansion around x = -1, so that a = 0.
So, the first few terms are: ln(x+2) = 0 + (x-1)f'(-1)+...=(x-1)+...
It was asked to do the expansion around 0, and of course the first equation is correct, i.e.,
\ln(x+2)=\ln 2 + \ln(1+(x/2)) = \ln 2 + \sum_{n=0}^{\infty} \frac{(-1)^n}{n+1}(x/2)^{n+1}.
Finally you should think about the domain, where the series is convergent!
x' = x+1
or
x' = \frac{1}{2}x
Why not just use the Maclaurin series formula
f(x) = f(0) + f'(0)\,x + f''(0)\, \frac{x^2}{2!} + \cdots \:\:?
It is really very simple to use in this case.
Yes, that's what I had in mind. For the x terms in your expansion. Can I do:
f(x) = f(0) + f'(0)(\frac{x}{2}) + f''(0)\frac{1}{2!}(\frac{x}{2})^2 + ...
Your could write that, but you would be WRONG. The Correct form of the expansion is exactly as I wrote it. Your series above is for f(x/2), not for f(x).
ok I think I get it now.
I use your mclaurin series to expand the formula..
Then based on the series outcome, we build the sum. So the following sum is still correct:
Is that what it means when it says "expand ln(x + 2) about a = 0?" I'm not familiar with this type of terminology. What the heck is "a"?
Chet
Chet
My guess would be that it was a typo, and should have said "...about x = 0".
