Optimal Degree for Approximating Cosine with Taylor Series
hadroneater
What degree Taylor Polynomial around a = 0(MacLaurin) is needed to approximate cos(0.25) to 5 decimals of accuracy?
taylor series...to complicated to type out here
remainder of nth degree taylor polynomial = |R(x)| <= M/(n+1)! * |x - a|^(n+1)
where a = 0 in this case
and
M >= |f^(n+1)(t)|
I don't really get this question at all. I know that |R(0.25)| = 0.00001 <= M/(n+1)! * |x - a|^(n+1)
But how do I get M when |f^(n+1)(t)| is unknown? I don't even know what |f^(n+1)(t)| means!
f(n+1)(t) is the n+1:th derivative of f(t). So is your plan to find the lowest upper bound for Mn? It might be easier (and more likely to be correct too) if you just calculated enough terms from the series until you have the desired accuracy.
But we aren't marked on that...it has to be through the remainder method.
Anyways, I know what f^(n+1)(t). I just don't know what to plug in for t. And after that, doesn't it just become a plug-and-check game for n until I get less than 0.00001?
All derivatives of cosine are \pm cosine or \pm sine. What is the largest possible value of a sine or cosine?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
