Telescoping Method & Partial Fractions PLEASE HELP
In summary, the author is trying to use the telescoping method to find the sum of a series from 1 to infinity, but they are having trouble following the steps exactly. They also mention that they are confused about what the final result should be and need help with partial fraction decomposition.
BuBbLeS01
602
Telescoping Method & Partial Fractions...PLEASE HELP!
Find the sum of the series from n=1 to infinity...
2/(4n^2-1)
I want to use the telescoping method...
2/(4n^2) = 2/[(2n-2) * (2n+1)]
I am following an example in my book and this is where I don't know what they did next...but they got
An = 1/(2n-1) - 1/(2n+1)
Correct. And how do you write down the partial fraction decomposition when your denominator has two nonrepeated, linear factors?
BuBbLeS01 said:
2/(4n^2-1)...
Hi BuBbLeS01! :smile:
I'm confused … 1/(2n - 1) - 1/(2n + 1) is 2/(4n² - 1). :confused:
Next step … what is An + An+2 ? :smile:
Right, he's asking how the author got that result. So he needs to revisit partial fraction decomposition.
2/(4n^2) = 2/[(2n-1) * (2n+1)]
So the LCD for the right side would be (2n-1)*(2n+1)
2(2n+1)/(2n-1) + 2(2n-1)/(2n+1)
For some reason that doesn't look right though??
Hold on a second, you dropped a "-1" somewhere along the way. It should be this:
[tex]\frac{2}{4n^2-1}=\frac{2}{(2n-1)(2n+1)}[/tex]
That's because it's not right, and I don't understand why you're writing it. What you're supposed to do is this:
[tex]\frac{2}{(2n-1)(2n+1)}=\frac{A}{2n-1}+\frac{B}{2n+1}[/tex]
That ought to jog your memory enough to finish.
Hi BuBbLeS01!
That's because you've put a + in the middle instead of a - . :smile:
So is it just...
2 = A(2n+1) + B(2n-1)
A = 1 and B = -1
:smile: Yes! :smile:
WOO-HOO LOL Thank you...I think I got it from here :)
What is the telescoping method?
The telescoping method is a mathematical technique used to simplify and solve a summation or series. It involves identifying and canceling out terms in the summation that are the same, resulting in a simpler expression.
How is the telescoping method used in partial fractions?
In partial fractions, the telescoping method is used to break down a rational function into simpler fractions that can be integrated more easily. By identifying and canceling out common terms, the rational function can be rewritten as a sum of simpler fractions.
What are the steps for using the telescoping method in partial fractions?
The steps for using the telescoping method in partial fractions are as follows:
1. Factor the denominator of the rational function.
2. Write the rational function as a sum of simpler fractions with undetermined coefficients.
3. Use the method of undetermined coefficients to find the values of the coefficients.
4. Rewrite the rational function as a sum of the simpler fractions with the determined coefficients.
5. Use the telescoping method to simplify the expression by canceling out common terms.
6. Integrate the resulting expression to find the solution.
What are some common mistakes when using the telescoping method in partial fractions?
Some common mistakes when using the telescoping method in partial fractions include:
- Forgetting to factor the denominator of the rational function.
- Incorrectly identifying and canceling out common terms.
- Making errors in the method of undetermined coefficients.
- Forgetting to integrate the final expression after simplification.
To avoid these mistakes, it is important to carefully follow the steps and double check all calculations.
How is the telescoping method helpful in solving integrals?
The telescoping method is helpful in solving integrals because it simplifies and breaks down a complicated rational function into simpler fractions that can be integrated more easily. This leads to a more efficient and accurate solution to the integral.
