Television steering coil control circuit
The discussion focuses on the control circuit for raytracing in CRT televisions, specifically how steering coils manage beam deflection. It highlights the use of two sawtooth generators—one for horizontal and one for vertical deflection—where the horizontal generator creates a slope for side-to-side movement and a return line for retrace. The vertical sawtooth operates at a lower frequency, often using a stepped sawtooth to ensure even horizontal scanning. Timing pulses synchronize the sawtooths for smooth video output, with vertical and horizontal holds adjusting the signal generators to match incoming signals. This detailed explanation clarifies the mechanics behind CRT television beam control.
learningphysics
Homework Helper
Hi. I'm trying to find information about the circuit which controls raytracing within a television CRT tube (the circuit which controls the current through the steering coils deflecting the beam up down left and right)... How is this precise raytracing accomplished... what type of circuit is involved?
It's a sawtooth generator, actually two of them-- the horizontal and vertical. The horizontal sawtooth slope will cause the beam to move from one side to the other and the return line performs retrace. Same type of thing with the vertical, except the frequency is a lot smaller. IIRC, most sets actually use a stepped sawtooth for the vertical so the horizontal scan is even, otherwise your lines will tilt downward from the left to the right.
There are timing pulses between frames to synchronize the sawtooths so you get smooth video. The vertical and horizontal holds are there to tweak the signal generators to the incoming signal.
Hope this helps.
That helps a lot! Thanks!
BTW, linkage:
http://www.ee.washington.edu/conselec/CE/kuhn/ntsc/95x4.htm
It was hiding in plain sight in my Favorites folder.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
