Temperature and pressure in sauna?
Pouring water onto sauna stones causes a complex interaction of pressure and temperature changes. Initially, the water cools the rocks, leading to a decrease in temperature, while the boiling water generates steam that increases the sauna's temperature. The pressure in a sauna remains close to atmospheric levels, but can slightly increase due to the added steam. In a controlled sauna environment, the temperature drop from the rocks can be compensated by the heater, maintaining overall heat levels. Ultimately, the specific conditions of the sauna, such as its volume and ventilation, significantly influence the resulting pressure and temperature changes.
AudriusR
Imagine that I pour a bowl of water onto the stones in sauna. So, the problem is that I need to estimate how much did the pressure and the temperature change in cause of this action.
Detailed answer would be very appreciated.
My attempt : pressure and temperature would decrease, because heater should boil and evaporate the water,which I poured.
Any other ideas?
Science news on Phys.org
Welcome to PF!
Saunas are not sealed, so the pressure in them never differs from the atmospheric pressure outside by more than an immeasurably tiny fraction.
Pouring water on the hot rocks will cool the rocks, but it also efficiently transfers a great deal of heat into the water, which then goes into the air as the water boils. Injecting 100C steam into a 50C sauna will most definitely heat up the sauna.
russ_watters said:
Welcome to PF!
So you're saying that after I had poured the water, pressure did not change?
A sauna is a rather complex system to take a look at like this. Most saunas are electrically heated, and therefore actively temperature controlled. So changing the temperature in the system will cause the control loop to add more heat to the system.
Saunas also must be well ventilated. A sauna that isn't will quickly start to asphyxiate its occupants. That is a bad thing.
Finally, there are a huge variety of saunas with different volumes, materials of construction, stove designs, amount of rocks in the stove, size of rocks in the stove and materials of rocks in the stove to store heat.
For your sake, let's look at a heat storage sauna. Let's say it has 10m3 of air inside and it has a 1000 kg pile of rocks that has been heated to 600°C. We'll hang an adiabatically insulated rigid container of water over the stove with a dosing valve on it (so that volume is conserved) and wait for a temperature sensor to come to equilibrium at 100°C at eye level on one of the benches at the wall.
At the moment the system equilibrates, we'll seal all the openings to the sauna. Assuming air is an ideal gas, that traps (101 kPa x 10 m3) / (373 K x 8.314 J/mol-K) = 327 mol of air inside the sauna.
Now, we'll dispense 1 kg of water or 55.6 mol from the bag.
The water will hit the hot rocks and vaporize. That absorbs 2270 Joules from the system.
We'll assume the rocks are mostly silica, so they have a specific heat of 0.7 kJ/kg-K. That water is going to lower the average temperature of the stove by 3.2K. For simplicity, let's assume that it lowers the temperature of the whole system by 3.2K.
With that, again assuming that the wet air is an ideal gas, we'll now have a sauna pressure of: [(327+56 mol) x 370 K x 8.314 J/mol-K]/10 m3 = 118 kPa.
So the temperature inside of our sauna reduced by 3K and the pressure increased by 17 kPa.
http://saunascape.com/2011/06/how-much-water-can-i-toss-on-the-sauna-rocks/
  • · Replies 19 ·
10K
  • · Replies 32 ·
  • · Replies 69 ·
  • · Replies 25 ·
