How do you convert temperature differences between Celsius and Kelvin?
  • Thread starter Thread starter lizlyn
    Temperature
The temperature difference of 57.0°F converts to 31.67°C. This value remains the same when expressed in Kelvin as a temperature difference, resulting in 31.67K. The key point is that the size of a degree Celsius and a Kelvin are equivalent, but their zero points differ. Therefore, when measuring temperature differences, the zero point does not affect the numerical value. Understanding this concept clarifies why both Celsius and Kelvin yield the same difference in this context.
lizlyn
The temperature difference between the inside and the outside of a home on a cold winter day is 57.0°F.
express in C and in K
Tf = (9/5) delta Tc
Tc = Tk - 273.15
I used the first equation to find that the temp difference in C is 31.67
I then thought that you added 273 to that temperature to find Kelvin but on my homework the answer key said that the correct answer is 31.67K ... i don't understand how the two can be equal?
The size of a kelvin and the size of a degree C are the same (by definition) they are only different in where you start counting from
If you are measuring a temperature difference does the zero point of the scale matter?
lizlyn said:
Tf = (9/5) delta Tc
That's to convert changes in temperature between Celsius and Fahrenheit scales.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
