Temperature difference in a resistor
The discussion centers on the use of resistors to prevent flickering in LED map lights in a vehicle. A 330-ohm resistor was soldered to ensure the LED lights operate correctly by allowing the sensing circuit to detect a current draw at lower voltages. Concerns were raised about the temperature of the resistor and its potential to cause a fire, with calculations indicating that the resistor would dissipate about 0.4 watts under normal conditions. It was noted that the 2-watt rating of the resistor is conservatively chosen to keep temperatures low, and the heat generated depends on power dissipation and environmental conditions. Overall, the modifications appear effective and safe for use in a car's lighting system.
Bago
Hey,
I'm an absolute newbie and have just this one question:
When I installed LED map lights, they would flicker unless the door was open. After someone advised me that I should solder resistors (which I did) the problem was fixed, BUT: I would like to know what is the difference in temp as I down want to start a fire in my car.
Resistors are 2w 330ohm, I used T4W LEDs for which I guess are about 0.5w, and for voltage I think it's 12v.
This is a guide from another forum:
With the lamps flickering, connecting a 100nF capacitor across them stops the flickering, proving this was AC fast pulsing in nature, with effectively a low voltage - but of course no DC current flows through the capacitor . Connecting a resistor across the the lamp causes them to operate at full brightness due to the DC current draw - i.e. the controller senses the load correctly and turns on the power. I think that the problem may be that the LED lamps do not take much current until there is at least about 3V across each LED and the sensing does not reach this level. Adding the resistor allows the sensing circuit to detect a current draw at a lower voltage, so the light comes on .
I tried a few different values of resistor and could get it to work properly with 500 ohms or less. I chose a value of 330 Ohms, so as not to draw too much power. 12V with 330 Ohms draws 36mA, so not much on top of the festoon lamp's 120mA. Worst case dissipation might be 14.5V^2 / 330 = 0.64Watts. To keep the temperature low I used a 2Watt resistor. This is very conservatively rated.
Here are a few photos of the light unit:
Difference in temperature between what and what, and in which conditions?
Connected to 12V, the 330Ohm-resistor (resistorS?) draws something like .4W.
12V is not the operating voltage of typical LEDs, however.
However, these LED's (T4W ) are designed for 12V car systems as a direct replacement for the
"dome" lights etc in a car cabin
They have their own built in current limiting resistor and heatsink
The external resistor mod to stop flickering is an ineresting one :)
Dave
I'd like to know how hot can resistors get, as I don't want them to melt any plastic and cause a fire.
That depends on the power they get and the temperature and heat conductivity of the environment.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
