Temperature Hotter at Top of Bulb - Why?
  • Thread starter Thread starter sheikhfahad
    Hot
The discussion centers on the observation that the top of a bulb may be hotter than the sides, but participants emphasize the lack of sufficient information to provide a definitive answer. A detailed description of the apparatus, methods, and goals is necessary for meaningful assistance. One user suggests that the temperature difference could be related to tungsten filament evaporation affecting light absorption over time. The inquiry also includes a request for help in investigating the relationship between power and temperature, questioning whether temperature decreases as power increases. Overall, the conversation highlights the need for more context to address the temperature issue effectively.
sheikhfahad
CAn you tell me why will the temperature of the surface will be hotter at the top on the blub rathen than on the side?
thank you
No, we cannot tell you why the top might be hotter then the sides. Why? Simply because you have not provided enough information to even guess. If you want meaningful help with this project you will need to post a detailed discription of your appratus, your methods and your goals.
Further, I would appreciate it if you would use a single thread rather then starting a new one for each question.
Thanks,
Integral
alright i am sorry
Thanks,
Integral
Is it because "The tungsten filament evaporates more rapidly as the temperature of the filament goes up. The evaporated tungsten particles tend to deposit on the glass envelope, causing over time, an increase in light absorption. Eventually, the filament material will evaporate enough to cause the filament to break, completely ending the life of the lamp."
i am doing an investigation to find the relationship between power and temperature?
need to find the surface temperature, also can u tell me how the graph would look like for the power and temperature. will it be as power increase the temperature decrease?
thanks and i am sorry for the 2 post
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
