Temperature Rise due to Increase in Pressure (Liquid)
The discussion focuses on calculating the temperature rise of diesel fuel due to an increase in pressure, specifically from 150 psi to 1155 psi, using a pump with 500 hp operating at 524 gpm. The user calculated the mass flow rate to be 3688 lb/min and the work done by the pump as 21,204 Btu/min. The key formula used is -W=m(h1-h2), where h1 and h2 represent the enthalpies at the inlet and exit pressures, respectively. The conversation highlights the importance of pump efficiency, with a noted efficiency of 70%, which affects the enthalpy change and temperature rise calculations.
  • Understanding of thermodynamics, specifically enthalpy and specific heat concepts.
  • Familiarity with pump efficiency and its impact on energy transfer.
  • Knowledge of fluid mechanics, particularly the behavior of incompressible fluids like diesel.
  • Ability to use thermodynamic tables or equations for specific substances, such as diesel fuel.
  • Research how to use enthalpy tables for diesel fuel to find h1 and h2 values.
  • Learn about the specific volume of diesel fuel and its role in pressure and temperature calculations.
  • Explore the relationship between pump efficiency and energy conversion in fluid systems.
  • Investigate the effects of pressure on the thermodynamic properties of liquids, particularly diesel.
Engineers, thermodynamicists, and anyone involved in fluid mechanics or pump design, particularly those working with diesel fuel systems and energy transfer calculations.
Skez
I need help finding the temperature rise of a liquid (specifically diesel) due to a pressure increase. The system contains a pump at 500 hp and runs at 524 gpm. The inlet temperature is 75 F and the pressure is 150 psi. The exit pressure is about 1155 psi. I have the specific gravity as 0.841. I've reduced my formula to -W=m(h1-h2) where W is the work of a pump, m is the mass flow rate, and h1 and h2 are the enthalpies. I've calculated the mass flow rate to be 3688 lb/min and the work as 21,204 Btu/min. Now, I'm stuck because I can't find the enthalpy for h1 to solve for h2. When I have h2, I was going to use that and the exit pressure to find the final temperature.
So, am I doing this correctly? And if so, how can I determine h1? I can't find any enthalpy/pressure/temperature tables for diesel.
Science news on Phys.org
The specific heat of No. 2 Diesel is about 0.43 BTU/lb-F:
http://www.methanol.org/energy/resources/alternative-fuel/alt-fuel-properties.aspx
This should allow you to calculate a temperature rise due to the fuel absorbing the pump work.
OH! So, if the pump is working at maybe 70% efficiency, it's safe to assume that 30% of the horsepower isn't moving the fluid and is converted into heat? Then, I'd just take that number and find the temperature rise?
Thanks a lot by the way!
Pretty much.
Strictly speaking the fluid temperature will rise with pressure increase, even if no irreversible work is applied. But that increase is very small.
Well, I think I have an appropriate number. Thank you both so much!
No. If the pump is working at 70% efficiency, then 70% of the supplied electrical power translates into enthalpy change. Since diesel fuel is nearly incompressible,
h2-h1=Cp(T2-T1)+V(P2-P1),
where V is the specific volume of the diesel fuel (the reciprocal of the density).
Chet
Oh, I see! Thanks a lot! Using your formula and a different method, I was able to come out with similar answers! I normally use tables so that formula helped me immensely!
  • · Replies 42 ·
  • · Replies 23 ·
9K
