Temporal order of events seen by different Lorentz observers
  • Thread starter Thread starter spaghetti3451
    Events Lorentz
spaghetti3451
Three events, ##A##, ##B##, ##C##, are seen by observer ##\mathcal{O}## to occur in the order ##ABC##. Another observer, ##\mathcal{\bar{O}}##, sees the events to occur in the order ##CBA##. Is it possible that a third observer sees the events in the order ##ACB##? Support your conclusion by drawing a spacetime diagram.
Here's a particular placement of the events ##A##, ##B##, ##C## in the order ##ABC## as seen by observer ##\mathcal{O}## (##t##-##x## coordinate system) and in the order ##CBA## as seen by observer ##\mathcal{\bar{O}}## (##t'##-##x'## coordinate system):
I find that not all placements of the events ##A##, ##B##, ##C## on the spacetime diagram simultaneously produce the orders ##ABC## and ##CBA## as seen by two different observers ##\mathcal{O}## and ##\mathcal{\bar{O}}##.
How I proceed with demonstrating whether or not a third observer sees the events in the order ##ACB##?
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
