Calculating Height & Velocity of a Tennis Ball Hit at an Angle
In summary, the tennis ball is hit from a height h above the ground with a speed V and at an angle alpha to the horizontal. It hits a wall at a horizontal distance d away. Air resistance is negligible. To find the expressions for the height and velocity of the ball when it hits the wall, you can resolve the velocity into horizontal and vertical components and use the suvat equations. The horizontal component of the velocity is constant, while the vertical component is affected by gravity. The goal is to find the time at which the ball has traveled a distance d, which can be done by setting D (displacement) equal to Vo*cos(alpha)*t and solving for t. The displacement kinematic equations for this simplified projectile motion are X
dopey9
32
a tennis ball is hit from a height h above the ground with a speed V and at an angle alpha to the horizontal. it hits a wall at a horizontal distance d away . Air resistance is negligible
can anyone find expressions for the height and velocity of the bal when it his the wall for me to compare?
thankz
try resolving the velocity into horizontal and vertical components. then see what you can do with the suvat equations.
This is the case of simplified projectile motion, let me give you a crash course somewhat quickly.
If we assume gravity is the only acting force on the ball then the horizontal component of its velocity is a constant since the gravitational force is assumed to be entriely vertical. (downwards of course)
Thus Vx = Vo*cos(alpha)
Where Vo is the initial velocity and alpha is the launch angle measured TOWARDS the upward vertical FROM the horizontal in the direction of motion.
Vx is the x component of velocity
By applying some basic kinematics we find Vy = Voy*sin(alpha) - g*t
From the pythagorean theorem V = sqrt(Vx^2+Vy^2)
now the goal for you is to find the time at which the ball has traveled a distance d.
I'll give you a hint:
set D = Vo*cos(alpha)*t and solve for t.
Notice that the displacement kinematic equations given the assumptions are:
X = Vo*cos(alpha)*t
Y = Vo*sin(alpha)*t - 1/2*g*t^2
Assume you start at (x,y) = (0,0) and you will end at the point (D,h)
FAQ: Calculating Height & Velocity of a Tennis Ball Hit at an Angle
1. How do you calculate the height of a tennis ball hit at an angle?
The height of a tennis ball hit at an angle can be calculated using the formula h = (v0*sin(θ))^2 / 2g, where h is the height, v0 is the initial velocity, θ is the angle of the ball's trajectory, and g is the acceleration due to gravity.
2. What is the initial velocity of a tennis ball hit at an angle?
The initial velocity of a tennis ball hit at an angle can be calculated using the formula v0 = v*cos(θ), where v is the speed of the ball and θ is the angle of the ball's trajectory.
3. How do you determine the angle at which a tennis ball was hit?
The angle at which a tennis ball was hit can be determined by using the inverse of the previous formula, θ = arccos(v0/v), where v0 is the initial velocity and v is the speed of the ball.
4. Can you calculate the velocity of a tennis ball after it bounces off the ground?
Yes, the velocity of a tennis ball after it bounces off the ground can be calculated using the formula v = v0*sin(θ), where v0 is the initial velocity and θ is the angle of the ball's trajectory after the bounce.
5. How does the angle of the ball's trajectory affect its height and velocity?
The angle of the ball's trajectory has a direct impact on both the height and velocity of the ball. A higher angle will result in a higher initial velocity and a lower height, while a lower angle will result in a lower initial velocity and a higher height.
10K
