Calculating Tensile Lap Shear Strength: How Can I Determine the Shear Area?
To calculate tensile lap shear strength, divide the breaking force (500N) by the shear area, which is determined by multiplying the bond's length by its width. The confusion arises when the foil tears outside the bonded region, indicating that the bond's shear strength cannot be accurately assessed if the metal fails first. The tensile strength of the copper will influence the results, suggesting that a thicker copper or a smaller bond area may yield a more accurate measurement of the bond's shear strength. Ultimately, the shear stress calculated will reflect the bond's performance at the point of copper failure, not the bond itself. Proper testing conditions are crucial for obtaining valid results.
Javaid
Hi,
I am new to the tensile testing and still learning and would really appreciate the answer to a problem that I have been having.
I performed a lap-shear test on two foils of copper bonded in single lap joint. The copper broke before the bond does giving me a force of say 500N. I want to calculate the tensile lap shear strength. As per my understanding it should be achieved by by dividing the breaking force, in Newtons (500N), by the shear area, in square millimetres. But which is the shear area? Is it the width of the foil/bond multiplied by the thickness of the bonded area or is it the width of the foil/bond multiplied by the length of the bond?
Also, can this test give me the shear strength of the bond? (As the answer to this question is based on the answer to the previous question, I will ask it afterwards but it is here in case someone is kind enough to solve this problem for me)
Thanks in advance :)
Javaid said:
Hi,
Hi; welcome aboard.
While I can't help with the actual problem, I have to ask you about terminology. Regardless of what you're trying to test, I would consider the point at which the foil tears to be the "shear area". I'm not educated in the field, though, so I might be missing something.
By shear area (cross-sectional area in square millimetres), I meant the value that will be used to divide with the breaking force to calculate tensile lap shear strength.
The foil tears outside the bonded region and I am confused how to calculate the tensile lap shear strength which should be be achieved by dividing the breaking force, in Newtons (500N), by the shear area, in square millimetres. Hence the question...
Okay. Good luck with it. I haven't a clue, but someone here will be able to help.
You can't calculate the shear strength of the bond if the metal itself already failed. The shear area of the bond you want is length times width. The tensile breaking strength of the copper divided by the shear area gives you the shear stress in the bond at the time of failure of the copper itself. The shear strength of the bond will thus be higher, so if you want to test it, you have to use thicker copper or a smaller shear area (reduced bond length) I would think.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
18K
11K
