Calculate Tension of Rope for 0.5kg Mass Dropped 0.5m in 1.5s
  • Thread starter Thread starter brenfox
    Tension
To calculate the tension in a rope supporting a 0.5kg mass that falls 0.5m in 1.5s, the acceleration is determined to be 0.444 m/s². The tension can be calculated using the formula T = m(g - a), resulting in T = 0.5(9.81 - 0.444) = 4.683N. The weight of the mass is calculated as w = mg = 4.905N. The relationship t - w = -ma is confirmed, showing that the calculations align correctly. The final tension in the rope is thus confirmed to be 4.683N.
brenfox
a mass of 0.5kg is suspended from a flywheel. if the mass is released from rest and falls a distance of 0.5m in 1.5s, calculate : The tension in the rope. acceleration is 0.444ms-2.
t-w = -ma
t = m(ag)
t = 0.5(0.4444=9.81)
t = 5.127n
w = mg = 0.5x9.81 4.9n
so t-w 0.227n is rope tension.
Check by inserting numbers into equation of t-w = -ma
so: 5.127 - 4.905 = 0.5 x 0.222.
The last equation doesn`t marry up?
The tension in the rope is:
T = m(g - a) = 0,5(9,81 - 0,44)
or...?
Likes 1 person
If you had the mass just sitting there with no acceleration then it would be simply T=mg
Since it's accelerating you have to subtract the force acting on it from the acceleration that it is going at which is F=ma so therefore:
T=mg-ma=m(g-a)=0.5(9.81-0.444)=4.683N should be your answer?
Likes 1 person
From the beginning
t-w = -ma
t=m(g-a) = 0.5(9.81-0.44)
= 4.683n so t = 4.683n
w=mg so w = 0.5x9.81 = 4.905n
S0 t-w = -ma
Checking... 4.683-4.905 = -0.5 x 0.444
Correct... i think.
t-w = -ma
t = m(ag)
t = 5.127n
It is convenient to denote the positive direction in the direction of acceleration. In this case, the mass accelerates downwards so take down to be positive. This gives mg - T = ma. Solving gives T = m(g-a). It is difficult to see where you went wrong in your attempt.
