Tension in Two Strings With Different Angles
To analyze the tension in two strings at different angles supporting a 200g mass, it's crucial to understand that the system is in equilibrium. Knowing the tension in one string and its angle allows for the calculation of the unknown tension in the other string. The equilibrium condition requires resolving the tensions into vertical and horizontal components, which can be achieved using trigonometric functions. The discussion emphasizes the importance of using two equations to solve for the two unknowns, specifically the magnitudes of the tensions. Ultimately, the problem was resolved with the assistance of other participants.
Cjjw
Hi, I have been stuck on this question for a while, and I need help figuring it out.
For a lab, we had two ring stands set up about 1m apart from each other, with the rings at different heights, and we tied a string between them. We then placed a 200g mass on the string. We had a LabPro with a force sensor attatched to one of the strings to read the tension, but we don't have the tension for the other string. We're supposed to resolve each tension into vertical and horizontal components, but I'm not sure how to do that when we don't have the tension in the one string.
Can anyone help me out with that?
You know that the mass is in equilibrium. Knowing one tension and its direction, and the direction of the other tension, you should be able to determine the magnitude of the unknown tension which keeps the 200g mass in equilibrium.
By the direction, do you mean the angle? And if so, how would I use the directions to determine the magnitude?
And would I be doing the two equations and two unknowns thing?
Ok, I figured it out. Thanks for your help!
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
